Just wondering if anybody is running these prepped rods at any sort of decent power 350awkw or above??? From the picture it looks as though they have ground off the piston squirter from the side of the rod. I would have though that this would cause a stress location along the side of the rod. I know its not on the thrust side but while one side is in tension the other is in compression via simple elastic beam thoery.
http://www.nismo.com.au/pricelists/General...s/conrodshd.jpg
Edited by rob82
https://www.sau.com.au/forums/topic/106123-uas-exchange-conrods/
Rob, the squirter puts oil down the thrust side of the piston. It would be of negligible benefit on the compression side without one on the thrust side as well. I would suggest the tensile effects caused by torque loads would be cancelled by the compressive loads during the ignition stroke unless the big end or gudgeon seized. This would be a fairly simple beam loading exercise using superposition of static loads using a basic shape as the stress is highest at the outer edges.
I understand Racepace Motorsport recommend original rods for most street builds of usable power, and UAS are offering an improvement by linishing the rods smooth to remove surface defects and stress concentrators. I would be concerned that the oil is still going in the right place but John seems to know what he is doing there at UAS.
I've beam polished RB26 rods and removed the squirter boss entirely. The only problem is that the way that the holes are drilled for the squirter, once you remove the boss you have a 2mm or so hole instead of a .5mm or so hole. I just braze the hole up from the bearing bore side before I resize the rod. There is plenty of oil spraying up from the piston cooling squirters and you dont need the extra from the rod squirter. I pulled an engine apart today that I did this to that has done 30,000km since and the piston and bore look like new.
If there is anywhere that a 26 rod will break it is around the oil squirter as there are some pretty sharp edged. The engine i pulled apart has gone over 10,000rpm on missed gear changes and the rods held together well.
Saying all that, why bother fiddling with the standard rods when you can buy a set of eagle rods for $800, they're brand new, stronger, have ARP bolts and a much better design and are lighter.
How do they cancel? If you look at relative postion of the rod at 90 ATDC of a ignition stroke the forces aren't directly in line with the centre of gravity so they cant cancel. You right in saying that the stresses at the outer edges will be greatest but I cant see how they would cancel. So if the squirter is on the thrust side then that side of the rod would be under compression for an ignition event. Which is probably ok as crack propagation is more likely to occur if it were under a tensile load.
The only stresses that I could see that would cancel (at some optimal rpm and crank position, maybe a harmonic point) each other would be some of the side load associated with the cranks resistence to rotation and the force of the rotation of mass of the conrod itself about is CG.
I may be wrong. THis is just how I see it.
http://www.skylinesaustralia.com/forums/in...howtopic=106291 <-- Pictures of the internals of said engine here.
Yeah whoops, my bad... I think this smilie sums up my facial expression at the time it happened :):D
What we have to consider here is each discreet loading at the highest load condition (90degATDC is near enough):
- the vertical load from the force of the piston which is slightly greater than the piston load (due to Pythagoras) and only acts directly along the axis of the rod (since it is a simple pin joint at each end), and
- the rotational load from the resistance of the big end bearing. This can be simplified to a static load in tesion on the thrust side of the rod and compression on the non-thrust side.
- in the case of simple beam theory we consider the inertial forces and can determine that they have limited effect on the outcome in this phase of rotation so apply a safety factor to calculations then ignore them.
In any engine the active forces have to be greater than resistance forces, else we would not have a working engine. So we can extrapolate from that statement that the friction forces from the rotation in the big end are miniscule compared to the piston thrust. This is also borne out by the fact that the bearings do not disintegrate under heat due to friction.
So through superposition of forces the tensile (negative and miniscule) force on the thrust side of the rod + the compressive piston force (positive and very large) gives a slightly smaller but still large compressive load on that side. Additionally the non thrust side will be a compressive + a compressive so will be slightly larger overall.
I hope that helps you understand.
i think those in the pic are 6 inch vg30 ones.
if your gona make good power get some aftermarket ones.
although dirt has proved its not really nesesary. just insurance.
stress relieving somthing that is on the edge is a good idea. but im pretty sure arp doesnt make bolts for the 26. only the vg30.
i had to get tomie ones.
people use them but the nut doesnt thread on all the way.(dodgy)
VG30DETT bolts are actually slightly longer that the factory RB26 bolts and there is plenty of thread, the regular VG30 bolts are nowhere near the right length, SR20 ones are about 2 threads too short. There is nothing dodgy about using the VG30DETT bolts, we use them regularly.
We use SR20 bolts....good length. Dont know about being "2 threads" too short ??
Only problem is having 4 bolts left over....but after 3 rebuilds you have a full spare set.
Edited by DiRTgarage
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
