Not sure why, I pumped my tyres last week on my good old stockies at 35 on all 4 wheels, after 1 week all the wheels deflat pretty dramatically, lost 6 psi on each wheel and the rear left even more 20!!! I do normal road driving but do infact turn corners quite hard and fast.. does this effect it? if so does it effect it that much that it looses 6 psi in 1 week?? thanks all..
https://www.sau.com.au/forums/topic/10620-stock-wheels-deflate/
i think that u know that u got bad damage on ur tyres if u see a ring that follows your tyres ... hard to explain ... cause i had a leak in one of my tyres and it developed this very noticeable mark which followed the outer edges of the tyre ... but i'd get it looked at ... also u might wanna run ur tyres harder... as it improves tyre wear and ride comfort ... but might give a bit less traction ... someone correct me if im' wrong...
The consistant loss across all three tyres is odd. Did you use a service station gauge when you inflated them to 35 the first time? They are notorously inaccurate and unreliable, I have a little $20 tyre gauge that I leave in the glovebox for checking pressure (in fact, only use it - dont even bother with the servo gauge most of the time).
BTW the new 'digital' gauges at some servos appear to be crap most of the time too...
I have been told that you should never check you tyres once you have driven your car, only when they are cold. The resaon being that the further you drive and the hotter the day the more pressure you will have in your tyres.ie hot air expanding.
1 check all pressures when cold with $20 gauge from kmart and remember how much each are down.
2 Drive to petrol station if you dont have a compressor at home, add the correct amounts to each tyre and check with your own tyre gauge.
This way you will know for sure, how much of a leak you, if any!!
ps down 20psi i think you have a nail
Good luck
I checked my tyres (Falken ZE-502 - 225's) on the weekend and they dropped about 4 PSI in about 6 weeks.
My mum got her tyres pumped up with urmmm whats it called nitrogen or something (wild guess i have no idea what its called). Cost her like $60 to have it done and mannn their is a difference. Tyres are never REALLY hot, never changed PSI and drives more smoothly.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
