im really interested to see if anyone is running a gt30 500hp turbo on their rb25 on these forums with an a/r.82 exhaust housing and if so what power are they getting in rwkws and at what boost pressure and rpm does it reach full boost by with what supporting mods??? cheers carl.
in the 500hp the .63 really doesnt choke it, its when you get the slighty bigger comp wheel for the 550hp that the .63 would hold back.
i reckon the 550hp would come a damn sight close (if not make) 300rwkw on 20/22psi if in a .82 rear.
I went 270rwkw with 600hp on 17psi.
But then, when your talking 10/15kw thats a simple matter of dyno calibration really, your 280 could be 265 on the dyno i was on, or vice versa... if you see where im going with this :unsure:
Its hard to compare 10/15/20kw differences IMO.
yeah the .63 would probably be the better choice, gives better low end grunt. all the .82 would do is lag your combo out, unless you also go the bigger comp wheel as was stated earlier by R31Nismoid. all you really need to get more potential from your turbo is cam work, forget about a larger A/R turbine.
bugger all if you ask me, maybe 20rwkw which you wont really feel.
i doubt id feel 280 going to 300, maybe @ 150rwkw going to 175 or something you would :)
i went 270 to 330, that i noticed :(
wow , a few different answers there. does anyone know what the difference would be in rpm, what 300rpm , 500rpm? to spool up to full boost? i thought that posting here i might get some intelligent answers?? instead i get," i can get you a dyno print out for 300rwkws if you like". if i was just after outright power i wouldnt be playing around with such a small turbo would i? all im trying to do is discuss my options before going ahead or research before going ahead, i appreciate your help so far guys but weve come along way say since the sub zero workshop pulled 10.9 in a skyline over 5 years ago. they were using two of my turbos to pull 330rwkws . this was and is still impressive but now lots of peoples skylines are doing it and probably with less lag than is associated with two big twins. im just trying to see before i try to extract a little more. im a very happy with the way it drives at the moment and yes power does come hard at 3500/3800rpm. with boost starting at just over 2000rpm. has anybody actually driven or owned a skyline with a gt30 500hp rated turbo with a a/r.82 exhaust housing? because if it takes another 500rpm to spool the thing then know i probably would not bother but if its less than i would probably consider it.
Edited by bigcarl
ive already got 281rwkws with a/r.63 exhaust housing, thanks for reply anyway.
I've got the same setup making 225rwkw... can you tell me your other mods?
(I'm running standard internals and 16psi boost)
low mount stainless manifold, ces split 3 inch dump pipe into a 4 inch magic cat, then 3 inch continueing to barrell style muffler with 4.5inch tip. 600x300x80mm front mount intercooler with stock plenum and pipeing. link ecu running 550cc injectors. splitfire coils. motor has been fully rebuilt with wiseco forged pistons on prepped gtr rods. running 8.5 to 1 comp. head mild port, running tomei poncams step ones 256inlet and exhaust, no adjustable cam gears. 600hp bosche fuel pump. i hope i havent left anything out.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
