you sure its missing, i thought mine was so changed my plugs and coil packs was still doing it turned out to be the fuel pump acting up. get it on a dyno iam sure thay will tell you what the problem is.
Come to think of it, its kind of doing the boost cut or feul cut thing. it is boosting ok, but just sperts and carries on. Then at idle it just misses every now and then.
the only thing i have done is put a front mount in thats all
mate, i also have a similar problem and after 3 years am still searching for an answer...
i've got my eyes glued to this thread!
hahahah well im hoping someone will have an answer for me, driving to work today was ok until about 5 minutes from work it jerked alittle down low but up high is ok. i dont know what the issue is
its a common problem. Its the valve seats. What happens is you bring a car like a skyline to Australia and run it on the shitty fuel and it valve seats get dirty and every now and then a valve doesn't seat properly temporarily losing compression on that stroke.
The valves slowly rotate... therefore every now and then not seating properly.
if you want it to go away, take off your head and get a valve seat grind.
Other than that, just leave it.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
