Hello
Just fixed the Boost Problem
Electronic Solenoid runing off the computer making full 18 psi at 4200
Have done 292 Dyno Runs so far and has been Driven on the street everyday
ripn burnouts and drifting.I am currently Fitting some slicks so i can take it to wenesday night Street meet
at eastern Creek
Lets see how it goes and how long it lasts
Doughboy is posting the dyno Printout
Sorry split some coke on it
I am sure you meant cola, didn't you? :dry:
No heat shielding around the POD
No visible ambient air feed
30 degrees Ambient Air Temperature
49 degrees Inlet Air Temperature
I’ll stick by my previous post;
Should we have an ET and TS guessing game?
My 20 cents is on a 12.5 at 120 mph
:P cheers :P
Edited by Sydneykid
Yeah sorry champ
i was comming on sunday
but on sat when i was checking my car on the dyno for the last time
i realised it was leaking boost and then i had a look why and found my plenium was cracked
so i couldnt repair it in time and gave up
i got some street slicks today and am fitting them to my car so i can take it drags on wenesday
i will post the time slip on thursday
I will be using Launch control Rev limiter so if people are there watching dont think im being a idiot reving its head off
Listen buddy
if your so confident in your car
LNEMUP
Any time
Wheres your so called RB31 In a dream or what
For the record
My dyno is Located in a sound proof room with extraction fans and Cooling fans.So on a hot day
The tempertures do rise in that room
I dunno what environment you live in but im sure when it gets hot the Temperture Rises
and no i dont run a pod filter cover as yet but when im at the drags my light is comming out and and ram tube is going on
so that will bring my air temps down
CYA at the track
Hope someone will LNEMUP
Edited by MR331307
The Bezerkly car has gone 124mph a couple of times too. If Daniel doesn't drive it right he's getting bashed in the carpark while I rape....errr.....RACE it for him.
He Jason - LNEMUP! :P
Adrian
Hello
i was at the track 2nite only got 2 runs first was 13.8 ET 116MPH
Then 12.6 ET 118MPH
First run died in the ass
second run Spined in first and second
When i went to do my third run Someone didnt tighten the radiator cap and then temps got hot and i wasnt allowd to run
When i fixed the problem It started Raining
Shit happens ill be out there next week again with the NOS setup and Taller Diff Gears which ill be changing to 4.56 as im only crossing the line at 5300rpm in 4th hopefully will run in the 10z
Then 12.6 ET 118MPH
And my prediction was :sorcerer:
It will be all wheelspin city or bog the dog.
I wasn't that far off, do I win the guessing competiton? :mad:
What's the prize?:)
:( cheers :D
Edited by Sydneykid
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
