GTST :)
I was about to say exactly the same thing.
MR331307
Good work for improving the times....but you still couldnt resist hey? Maybe leave the clown remarks at the door and people may show a little respect.
sorry champ SHORT fuse
lol
i am testing out this motor and trying to explain the progress to everyone and im left with blokes on here trying to put it down
fair enough its lasted maybe 3 months so fair but still not like ive treated it like a pensioners car.There are some really nice people on this forum and alot of keyboard warriors.
Ill update it as i get more progress out of the car.
OK
Wild 1 Motorsport is happy to say that the standard Rb25 motor has run
10.8 @ 128 MPH
Doing a 1.48 60" foot time and lifting the wheels in the air
Time for a cage and New safety Equipment
You can view some of the video Clips on www.wild1motorsport.com
Last run was using a 30 shot of gas Detuning to the engine to compensate.
We are trying to run mid to low 10 second passes out of the vehicle when it returns and then once this is achieved and if the engine is still running more nitrous and Boost to achieve a high 9 second pass.
Currently we have done a compression test and the engine is fine.Oil pressure is fine.
OK
10.8 @ 128 MPH
Wheres the 10 sec vid? Those are 12 sec passes
i tried
MT 275/28/15 street tyres and the best i could get was 11.3 with a 1.7 60"
now im runnin
10/26/15 MT full slicks and i got a 1.48 60 " .Theres no way a manuel IRS car will hook up any good without full slicks under the rear.I have HKS drag shocks as well under the car.
The reason for the smaller diameter slicks is so i could cross the Line at a Higher RPM as with the street tyres i was only crossing the line at 6600RPM or so and now im crossing the line at 7200RPM.But i still need to be crossing the line at 7700 RPM.I might play around with the tune and try to get the power on a lil quicker
the car still boged down a bit of the mark so we are going to launch a bit harder next time and hold the car flat till the end and try to run mid 10`s.Once i have run more then 10 runs at 10.5 or quicker,Then its time for more NOS and More boost.
Edited by MR331307
Mark Jacobsen - 1.358 60' - 255/50/16 MT ET Street Radials - 3470lb car
Shane Crichton - 1.51 60' - 255/50/16 MT ET Street Radials - 3500lb car
Me - 1.66 60' - 255/50/16 MT ET Street Radials - 3240lb car
They're all IRS Jason and Mark and my cars are manual. I think you just need to persevere with them.
Awesome work on the 10 though, mate.
Adrian
Maybe i will need smaller diameter street slicks but anyway i wasnt gonna waste money on Street tyres.I wanted slicks.
How much power are the top 2 making
The top car Very good ill be more then proud of that
But i aint wanting to run 1.5,1.6 60`s(not putting you down or being a smartass)
i want 1.3,1.4 constant 60's without have the need to burn the clutch or do to many stupid things to launch.
With Slicks hold 7500,Drop Clutch & hold on
Later on once i am running consistant then i will try to run similar numbers with street tyres.
AND ADRIAN NO NEED TO BE JEALOUS AND GO ON ABOUT RUBBISH. Once the cage goes in ill be back for more
Edited by MR331307
Good work on the ET's and TS's so far, it's a matter of practise and improvement. It was never going to happen first time out.
almost 350 dyno runs
The problem is you have had 350 FREE dyno runs to get it right. How much would you charge a customer for 350 dyno runs? Even at $50 a run (which is cheap) that's $17,500. I think I would much rather spend my time and money on an RB30 with forged internals and still come out $10K in front.
:P cheers :(
PS, word of advice, you are promoting a retail business, it pays to treat you potential customers with repect.
Edited by Sydneykid
For starters
350 dyno runs were on for reasearch purposes.
if i had to dyno a vehicle it will only take around 10 dyno passes and around $400 costing.I have done reaseach in the motor to get it to last and so far i think shes doing fine.
I am trying to retain the standard skyline Engine Drivetrain as a RB30 Might be a similar block but still didnt come out of my vehicle.As well i think that the RB25 and RB26 Motors are a much better bottom end compared to a RB30.
Any ways
research is still going on and will update as i go
Mate, I was trying to help you out and maybe offer a bit of advice. Obviously that was un-wanted and you have different goals. That's cool.
That's the end of my discussion on the subject. Good luck with your racing, i hope you run as fast as you want and do it safely.
I'm sorry I bothered.
Adrian
LINEMEUP i wonder what the rest of your business associates think about your attitude towards the public, because u dont show a very positive additude, and all u seem to do is bag people out and say they are not as good as you.
grow up ffs, u sound about 17 years old the way u act to other peoples comments.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
