ive released an update to the pocket pc edition which fixes the logging frequency (now its as often as pda can handle, ie as many log packets as sensor updates on screen, depends on speed of ur pda), and also creates seperate file each time for logging)
http://www.ecutalk.com
  • Replies 149
  • 1 month later...
ECUTalk v1.2 - http://www.ecutalk.com/
Combined Standard and Pocket PC versions into the single unified executable (single .exe also), based off the last Pocket PC release.
Added auto connect back in - it will connect on the given com port, select the sensors, and view gauges fullscreen on startup (after its set up).
Added in injector duty cycle % sensors, and added MPH and degrees F sensors (for speed/temp).
Left: Running on PC/Laptop
Right: Running on Pocket PC
More screenshots: http://www.ecutalk.com/screenshots.aspx
nah, you'll need a pocket pc. palms are the poor mans pocket pc :spank:
i think theres some software written for a palm out there somewhere called "palmz" this guy wrote it: http://ecu2.forumwise.com/profile.php?mode...ofile&u=440
on that note, i picked up a h2210 on ebay for $40 :dry: (though it has nearly all non-essential bits missing and bluetack/tape needed to hold battery in, but it works!)
rz1710 ipaqs can be found a bit over 100$, might be a reasonable upgrade
Edited by NewKleer
NewKleer, i need to get a new boost controller, and some other bits first, plus i am running out of places to mount this stuff. LOL. I think a lappy will do for now, the wife is riding my nuts cos i spend too much money, Blody women, you can't live with them and you can't shoot them.
a silly question, i take it this does not work on a Palm such as an m515???
if so how, cos i can't get it tp work
what about this?
http://eccs.hybridka.com/viewtopic.php?t=105
  • 3 months later...
ECUTalk v1.3 Released - http://www.ecutalk.com
1) Added ability to log sensors without showing them on gauges (when logging is enabled, checkboxes have a greyed out checkstate, indicated logging only)
2) Logging changed so it logs all packets (only gauges will drop packets/not update when cpu is falling behind, but all packets will be logged)
3) Colour setup for gauges added. Hard bit for you is coming up with a colour theme that looks ok!
4) Added Instant Fuel Economy Sensor - requires RPM, Injector and Speed kph selected to work
5) Changed DutyCycle/RH Sensors to calculate values from RPM and Injector/RH sensors (therefore requires them to be logged at least to work)
6) Fixed Timestamps when milliseconds are less than 100 (3 digits). Previously they would not have leading zeroes
7) Simplified gauges such that they will only display values within their range (however, logging will show the calculated value) and will no longer auto change their range to suit the values (as occasionally a weird value may be read which causes a unco gauge to be drawn).
8) Added an option to allow the full-screen mode to only use the "working area" of the screen. Eg, it wont cover taskbar in a normal windows desktop, and for carpc users with special frontends, it may mean gauges display properly if running ECUTalk from within your frontend.
9) Improved the saving of settings to .ini file. Note that the order of items in this .ini file matters - their names (what is shown before the ":") does not. Eg autoconnect, logging, selected sensors, working area option, injector size, gauge colours, etc are all stored in here.
10) Removed EGT sensor (it's useless, only ever reads 4.98v)
See screenshots below to better understand difference between selecting sensors for gauges (batt, duty, econ, temp) which you check once, and for logging (rpm, injector, speed) which are checked a second time to make them grey. Also shown is how you can set the colour of the gauges yourself.
ECUTalk v1.3.2 Released - http://www.ecutalk.com
This version fixes a few bugs and has some pretty big performance improvements.
Users of v1.3 and v1.3.1 should update to this version.
v.1.3.1 added a MPG sensor for Imperial users (and an option to switch between Imperial/Metric sensors).
1) Fixed issue in v1.3 and v1.3.1 which meant data packets weren't being dropped when CPU couldn't keep up
2) Increased performance of gauge drawing by ~250% (on my PPC, time to draw a gauge went from ~30ms down to around ~12ms).
3) Changed code to always draw gauges (even if data hasnt changed) in order to result in consistent amount of packets being logged per second.
4) Added option to specify minimum gauge update speed - higher value means more packets are logged due to less gauge updates (and hence more time for logging). Eg on my 568 Jornada PocketPC 2002, 10ms = ~5 packets logged/second, whereas 1000ms = close to full 50 packets). The setting ignored when not logging (it will just update as quickly as possible).
5) Improved consult streaming to allow more data to be read in and processed (rather than lost). Probably the best program for data logging due to the sheer amount of data able to be read in. On my desktop PC, setting minimum gauge refresh to 0ms (ie never skip a gauge redraw, hence uses most CPU), can log 35 packets/second of all sensors. Setting minimum refresh to just 50ms gives the full 50 packets/second. I compared this to Nissan Datascan, which can only log 16 packets/second on the same PC (and thats without gauges shown at all) with the same sensors.
6) Changed options controls to dropdowns rather than textboxes (i didnt realise id disabled the use of the soft input panel on PPC, so you couldnt change settings). If you want to enter a value other than shown, edit the .ini file.
7) Fixed logging time output, both to add in the missing leading zeros (eg it would show 7:5:7 for 7:05:07), and also added in a interpolated millisecond value for PPC users (which doesnt have a millisecond capability in standard time object).
8) Minor changes to individual sensors to better display on gauges, and slight changes to change config (units shown next to sensor rather than down bottom as often the units would overlap gauge).
9) Added a hidden option for CarPC users with frontends (eg Centrafuse) to manually edit .ini file to set custom top/bottom/left/right co-ordinates for full-screen mode. Example: FullScreenBounds_L|T|R|B:10|20|1000|900. Setting all to 0 will use default method.
If I was to have a PDA with the only connection being via USB, would this program still be able to work on the PDA providing I have the following cable:
http://www.blazt.biz/products/images/usblarge.JPG
I've read all 5 pages of this thread, but it's still all a bit confusing. I can't see why this wouldn't work?
Please let me know.
Thanks,
Richard.
i can see two reasons:
1) your PDA most likely does not have USB host capabilities (ie, its not able to have usb devices connect to it - its only able to act as a usb device to a PC)
2) the current usb blazt cable is based off a usb/serial converter which has no virtual com port drivers for windows ce (ie pocket pc/windows mobile)
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
