Hi ppls,
I am soon to rip the head off, replace valve springs, headgasket and oil restrictors.
I attempted to remove the oil restrictors out of a spare rb30e I have in the shed. I failed. :(
How are these removed? Is it possible to remove and install new without removal of the motor/sump?
I have seen other (non rb) blocks where the oil restrictor have a thread located in the top section of the restrictor, this allows easy removal.
:D
https://www.sau.com.au/forums/topic/107288-removal-of-block-oil-restrictors/
Hi ppls,
I attempted to remove the oil restrictors out of a spare rb30e I have in the shed. I failed. :)
Drill and tap.
Figured as much.
My main concern with drill and tap is leaving metal filings in the block.
I could grab a hoover or something as I drill or make an attachment to fit down the galley after its removed to suck out any possible filings but its always a worry.
Any suggestions?
Hopefully I don't have to report that engine failure Geoff. :)
I'm going to rip the ones out of the vl block and see how far I can push the old restrictors down. If the galley doesn't taper or do anything silly I will push the old ones down and simply drop the new ones on top.
While on the topic.. I've been told the RB26 Tomei headgasket kits from nengun come with the restrictors. RB25/rb20 doesn't. Yet they have similiar price.
Is this really the case or do the tomei restrictors have to be purchased seperately?
Either way I'll drop nengun an email and post back my findings.
Can you use a 26 gasket with a RB25DE head?
and the r32 rb26 head doesnt run vct either. oil/water galleries would be similar to r32 rb25de? Cylinder size is the same...
Solid lifters are always a bonus.....
Wonder if i should sell my fully rebuilt and ported head, and go the gtr head....? Depends...
This is where i am confused. I can get VG30DETT lifters for lsightly cheaper then what Tomei sell their kits for. It would be cool to run 260/10.25mm cams.
The theroy say that solid cams will make more power because they accelerate open/closed quicker, they are lighter etc. But the cost of doing it, only to have to shim/long term maintenance etc...well????
If i spend the same money on the combustion chamber and ports, and stuck with the 260/8.5mm cam ( a cheaper option),how much less power, if any, would it make????
Does having large lift cams hurt velocities/cylinder filling at low rpm like large duration cams???
oh, and this is on topic as ,umm, because when you run oil restrictors, ...well the hydraulic lifters also use oil :P
Hi all , correct me if I'm wrong but aren't the oil restrictors made of brass ? I seem to remember AJ removing one from an L series block by screwing a self taping screw into it and pulling it out with a slide hammer . I dont think the interference fit is real tight .
Cheers A .
I think this may answer some q's Roy.
http://www.overboost.com/story.asp?id=1132
Especially the 2nd to last paragraph, that says : Synchronizing lift with piston speed keeps airflow at optimal velocities through the ports
Awesome.
I'm a happy man. :P
I've since discovered the tomei restrictors are 1.5mm.
RB30 are 1.8mm
RB26 are 2mm
RB20/25 are 2.4mm
Thanks.
One last question... Does the rb26 tomei headgasket kitcome with 2 restrictors?
Running the hydraulic head I need to keep the two.
Awesome.
I'm a happy man. ;)
RB30 are 1.8mm
RB26 are 2mm
RB20/25 are 2.4mm
Thanks.
nope, they come with one. They are a very easy thing to make though.
No drama's... I am able to get my hands on another easy.
Proengines.. Whats your view on 2 x 1.5mm restrictors?
Obviously I won't hold you to anything you say as I doubt any one has actually tested, so its an unknown.
But technically speaking, does the hydraulics really need much more oil over its big brother solid?
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
