We are please to offer SAU forum members this great special on our popular Rose-jointed hardened steel adjustable castor rods.
Essential for drift and track, these come as a pair and are available to suit Silvia, Skyline GTS-T, GTR, GTS4, Laurel, Cefiro, 300ZX & more
We have a huge number of these kits in stock ready for immediate pickup & dispatch, so unlike other deals floating around the net, there is:
1. No deposit required
2. No minimum order
3. No waiting
4. Easy online payment options
5. No surprises
Deal with an established and trusted company! - Not a backyard trader
PURCHASE YOUR SET NOW FOR ONLY $175 DELIVERED!!
(Within Australia Only)
ADJUSTABLE CASTOR RODS FOR S14, S15, R33 GTS-T, R34 GTT
ADJUSTABLE CASTOR RODS FOR R32 GTS-T, S13, CEFIRO & 300ZX
ADJUSTABLE CASTOR RODS FOR SKYLINE R32 & R33 GTR & GTS4
So how can you place your order?
The answer is simple!
Visit http://www.justjap.com/forumcastorrodspecial.htm and purchase your Castor Rods online quickly and easily via paypal or credit card, or drop by our Kirrawee factory and pickup your set over the counter.
Please contact [email protected] if you have any questions, or reply here.
Dont forget to check out our huge range of new and used performance parts and import vehicles via our website at www.justjap.com
  • Replies 65
i use them on my GTR. I have had them on for about 6 months. I have done Eastern Creek, and other motorsport stuff like skid pan days, plus some street driving. They have held up fine. I periodically check them to make sure the adjustment part hasnt moved as i found when doing them up there is not much 'give' in the metal. ie as soon as the two surfaces touch, it's hard to torque them up any more, but having said that they have not moved a bit. I just used two big fcuk off spanners to make sure they were done up tight as could be when i put them on.
no complaints here at all. for the price (especially the special price!)they are a good product and i would use them again.
they have Beer Baron approval. In fact i will probably grab another set for my GTST as they are very good buying at this price.
Ok, I'll take the Beer Baron seal of approval and order myself a set :laugh:
Cheers
Paul
Thanks Paul, your order and payment have been received and your Castor Rods will be dispatched as soon as possible.
Cheers,
Steve
ok this is cool.... just wat i needed,
Just Jap u have pm ;)
Thanks Mass, I have replied to your pm
Regards,
Steve
My parts arrived today :D
Will be fitting them this weekend hopefully :D
Great service.
Cheers
Paul
Glad to be of service Paul :D
Regards
Steve
Thanks for all the orders guys, we have plenty left so get in quick to take advantage of this special forum member offer.
Cheers,
Steve
Hey Steve,
Very keen on a set for an R33 GTST.. have ordered and paid for a set over the net
Cheers
Johno
Cheers,
Steve
Hey Steve,
Cheers
Johno
Thanks for your order Johno, your payment has been received and your castor rods will be dispatched asap
Regards,
Steve
Thanks Steve recieved my item today! very quick service thanks mate!
Regards,
Steve
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
