Thanks for that Paul, excellent read... and I'll take your advice and read up further on the two.
Arkon, ROM tuning has been crossed out of my options list - too complicated, too little aftermarket support, too little tuners and at the end of the day too complicated to tune!
  • Replies 42
As posted many times, here is the problem.……..if you want more details so a search.
The standard Auto ECU has mapping to retard/cut the ignition on gearchanges. This gives nice, comfortable, jerk free changes and protects the gearbox from excessive torque loadings during the change.
NOT ONE after market ECU has that mapping, it is extensive, complex and therefore expensive to program. Supposedly there are more lines of code in the auto mapping than there are to run the engine.
If you completely replace the standard ECU you get no ignition retard/cut and the higher power you have the rougher the gearchanges and the quicker the gear box will wear out the 2nd gear bands and 3 + 4 clutches.
To retain ignition retard/cut you have to leave the standard ECU in control of the ignition timing. You can use any other ECU to run the injection. Hardly ideal but workable. Other than the Power FC which uses the AFM, the other ECUs’ use MAP sensors. You could use a Power FC to run the injectors and the standard ECU to run the ignition, obviously having no control over the ignition will limit your tuning options.
Using the SAFC on its own, you (or the tuner) have obviously hit the compromise limit. Less fuel needed, but the ignition is already too advanced. That usually happens around 225 rwkw. You may find an injector upgrade changes the mix of those components and the compromise becomes less. In my case I use the SITC to give some independent control of the ignition timing. Since the SITC sits between the CAS and the ECU it doesn’t interfere with the ignition cut/retard on gearchanges.
Some guys have had recent success using the EManage, to give more control over the injection and ignition. The early problems with the standard igniters seems to have been overcome. Do a search if you want more details.
Some guys swear by the chip upgrade, personally I have had no experience with that solution. Do a search if you want more details.
I think that covers the options, for the Stagea I looked at them ALL for some time and ended up with the DFA (SAFC equivalent), IEBC (boost controller) and SITC option. My power target is 210 4wkw (equivalent engine output to 230 rwkw in a 2wd manual). I can not see any reason why I won’t reach that target.
Hope that was of some help
:) Cheers :D
So the general concensus is that not even the Haltech would work? In my Dyno Results thread, we were throwing some ideas around and some people were in agreement that the Haltech will be able to overcome the auto dramas.
Anyways, back off to tuner this Sunday - I'll bring a pen and paper!
There are 2 dimension to the ECU and auto discussion, the first (#1) is the control the ECU exercises over the igntion timing on gearchanges (that's the post above).
The other (#2), far less important, discussion is whether or not the ECU has the relevant outputs for the Auto ECU to make the right choices for the gearchnge. Road speed, engine rpm, throttle position etc outputs. Most ECU's have those, they are very simple.
It's the #1 that no aftermarket ECU has.
:laugh: cheers :huh:
stan
have you though about the motec m800. herrod perfomane in melborne have it on a big hp ts50 and it controls the auto in it which is a tiptronic. give herrod a call see what they say i know its a ford but might give you a better idea of how to get it to work.
Herrod Motorsport 03 9464 5100
talk to Robert Herrod
Cheers mr 32
Haha, Wink, how about you give me the money to try that one out... then we'll talk!
OK someone give me some solid answers... I'm hoping to get this thing on the road in a week or two (making a decision that is)
This basically means MAF will be more accurate on the say 20x20 map grid as it can move around very freely based on air coming in and always show an increase (ie: use the map resolution you have).
You should read up on how they both work to understand as it will affect how the car runs and drives. You should also look for an ECU with closed loop feedback (fuel economy) and knock sensor support
MAF (commonly known as AFM or Airflow Meter)
mass air flow sensor
MAP
mass air pressure sensor
would the accuracy of a MAP incease on a 32x32 grid?
no it will not, as when you reach target boost say 12psi
the map sensor will always see 12psi and say the amount of air coming in is the same value, as the pressure is always the same. so it will just flat line along the LOAD axis despite more and more coming it.
basically v8 map sensor style. the tune increase purely on rpm increasing
pm sent to avoid thread getting off track...
OK received an email from UNIGROUP regarding the TSI; all up cost is around $2500 so it's not a cheap option. However, it doesn't look like they want to go near this option for my car as they offered the alternative of the SAFC which is 1/10 of the price ~
Mmmm... one option struck off then!
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
