Hi guys
Took the car down to the Motorplex to see how she'd run. It's an R32 GTS4 with an RB26 transplant and a plain bearing GT35 running 18psi. The car makes 408rwhp @ 7,250rpm
I probably should have checked the graph before I left as we were changing gears anywhere between 8,000 and 8,500rpm. So anyway, the best run was:
Elapsed Time: 11.995s
Terminal Speed: 118.11mph (190.07kph)
60' : 1.953s
330': 5.165s
660': 7.804s
660'speed: 151.57kph
1000': 10.078s
I did have previous 60' times of 1.7 so I guess I should have been able to shave a bit off that run above. It was still wheelspinning and torque steering a lot though.
So yeah, basically what I'm wondering is can I expect any better out of the car or is that about it?
Cheers!
https://www.sau.com.au/forums/topic/107875-can-i-do-better/
I would have thought that with 408 rwhp (305 rwkw) it would have run with a TS around 125 mph. A TS of 118 mph seems to me to be indicating a power more like 270 rwkw than 305 rwkw.
Or am I being too optimistic?
:D cheers :D
https://www.sau.com.au/forums/topic/107875-can-i-do-better/#findComment-2000016
Nope, that sounds about right to me, SK. Not too optimistic at all.
My prediction of 11.40 is based on the type of car and the mph it has actually run rather than the claimed power figure.
Adrian
https://www.sau.com.au/forums/topic/107875-can-i-do-better/#findComment-2000219
I brought the time slip and dyno chart to work today so that I can scan and post. Unfortunately I can only scan into a pdf format so by the time I've cut and paste etc it's in black and white. Once I get a bit of time later after the morning madness period I'll try and post them up.
Once you see the dyno chart then perhaps you could tell me if I am right or wrong in suggesting that the car could be quicker if changed at 7,000 - 7,250rpm rather than 8 or 8.2k like we were experimenting with
But yeah car was run in full street trim
https://www.sau.com.au/forums/topic/107875-can-i-do-better/#findComment-2002332
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
