Hey guys, finally got off my ass and test fitted my new rims and it seems i need a 10mm bolt on spacer on the front to clear the brakes.
Cant use slip on spacers as ive tried then the studs are too short poking out of the rims to tighten them up.
Another problem is that the smallest BOLT ON spacer ive seen is 25mm and thats way too much for my application (even 10mm is but what can i do)
Any help on where i can find 10mm spacers or get them fabricated?
Or any other ideas on what to do? Do i have to lengthen my studs?
Cheers
Kelvin
https://www.sau.com.au/forums/topic/107995-need-10mm-bolt-on-spacers/
If theyre your rims, when are they goin backwards on the Lada?
Throw em on and post up some pics!!! :D
Then u can pump the guards and spray the car midnight purple, would be like u never sold your GTR!! (Actually then u would have to spray the rims bronze) KGB-GTR
Also need my rims powdercoated/painted white, who did that fantastic work on those rims?
Hey kelly.. I don't know what you mean by slide on and bolt on.. How can you bolt on a spacer????...
anyways my 5mm spacers just sit in between the rim and the hub.. and the nuts go on top of the rim as always...
speaking of rims, i discovered that my spacesaver was a 4 stud anyways.. so if i blow a tyre.. im f**ked.
D@MN i better go check my cheese grinder just incase its a 4 stud too!
umm how can isay, i too have the 5mm slip on ones actually on there at the moment.
The bolt on ones slip on the hub and 5 new threads poke out too, so u keep the same length of thread. When i use my 5mm slip on ones, the thread shortens by 5mm if i went any bigger the nutwould sit on the stud on a thread or 2.
(Hope that makes sense, if someone with better knowlede of this stuff can explain it better please do).
Thanks to Garage-13 for the pic, im sure it will show u better:
FATGTS-R is right though i dont think u can get 10mm bolt ons cos there wouldnt be enough meat on the spacer and the original thread would poke out the other end.
ahhh I understand... sort of.. how does the spacer connect to the original thread AND the wheel though?
I see the extra holes there pressumably for the original threads, but then how does it sit on the wheel correctly, unless your wheel has 10 holes?
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
