i just got a autometer air/fuel ratio gauge ...
just wondering on how hard it is to install one of these and would any auto elec be able to do this or only specialised turbo workshops ?? thanks
i wanna get it done this saturday , if anyone could recommend any places in sydney would help thanks
https://www.sau.com.au/forums/topic/10801-installing-airfuel-ratio-gauge/
I did mine with a bit of help from ppl on this forum - do a search and you should find more info. The hardest bit is to find the O2 sensor's signal wire - you either need accurate ECU wiring diagram or top quality digital multimeter - look for the fluctuating voltages...... Anways, do a search !!
Cheers,
Guest nismogtsx
ok... easier... never put the wire on out in the engine bay... cause it will deteriate... plus there is voltage drop inbetween the O2 sensor and the ECU....
Do what i did... Goto the Apexi web page and go to the turbo timer manual.... in there it has a printable diagram of which pin on the ECU the O2 voltage input is... then just splice that wire and solder on.... As the apexi TT has an Air/Fuel ratio function...
Trust me... you want to be reading what the ECU is reading not what the O2 sensor is actually putting out.... For tuning purpose's
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
