http://video.google.com/videoplay?docid=-7...90388&q=skyline
Thought I may as well post it here since its a skyline and I cant find anyone who knows how to get this sound. I assume its turbo flutter due to no BOV. The car runs a T04Z. This is not a flutter thread so dont attack me on this one please, I know there have been 1000s of threads regarding flutter. All I want to know is how to get this specific sound on lifting the throttle cause I like its high pitch aggressiveness. Anyone care to share or if your car sounds like this what turbo are you running, are you running AFM, etc.
Cheers
https://www.sau.com.au/forums/topic/108111-how-do-i-get-this-specific-flutter/
I KEEP TELLING EVERYONE! ITS THE HKS RACING TYPE II BOV!
Around $450 delivered to Australia from greenline, perfectrun or nengun.
And beware the imitation ones for sale on eBay. Get the genuine thing.
And another thing, you have to run at least 1 bar of boost for it to blow off.
Hope I helped.
it sounds like a no bov system and a big single open mouthed
one of the rajab vls' sounds the same and its probably the same setup.
ditto with the PANNIC vl turbo. no bov, open mouted turbo and airflow meter upstream or map sensor so you can basically hear the compressor wheel surge as its straight into the atmosphere.
god help that poor compressor wheel :D
It does that because of the whole car setup, not just the BOV. It's a combination of the intercooler, piping, turbo, etc etc. And the fact that the HKS Racing Type II BOV is a single stage valve, and only operates under high boost levels. Hence, you get a lot of 'reverberation' through the intercooler and piping.
If you run this BOV on a relatively stock motor, it will sound much like a HKS SSQV. And similarly, if you get a HKS SSQV BOV on a setup with large intercooler and piping, you can get it to flutter.
Fluttering is caused by the pressure finding it easier to escape in places other than the BOV. You have to remember that the outlet for the BOV is only small, and filters and intercoolers provide a LOT of free room when you're blowing off.
As for the whistling sound, that's just how the HKS sounds. So if you want that fluttering whistle, get either HKS SSQV / HKS Racing Type II.
I recommend the SSQV for people running under 15psi, and the Racing Type II for people running over 15psi.
  • 1 month later...
Flutter like that of a VL turbo is not achieved with a blowoff valve kids, nor is it with the turbo intake open directly to the atmosphere... On my VL I have moved the AFM into the cooler pipes, and on the front of the turbo have fitted a 15cm long piece of 2.5" intercoolre piping with filter and mesh held over the end with a hose clamp. That is what makes the distinctive fluttering surge sound you hear VL's dropping here and there. Enjoy.
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
