  • Replies 131
Posted Images
Yeah what a great day so tired last night
The trip home was even more fun 800mm past the motel was a turn off to go to Colac / Geelong I took that to go home the first 50 km of that road were some of the best corners around, the next 100 kms think I only went around 10 corners in total
Here I was sitting on 100kph on a straight that was about 15 km long and I had a XR8 Ute come from nowhere and pass me I estimate the speed he passed me at was around 220 kph
Crazy F#$*(%G hick drivers keep it on the track not the road
Big thanks must go out to the slow drivers that pulled over to let the cars behind past and to the ones that didn’t please think of the others on the road next time
Nice pics ;)
Really wanted to go this year but had to miss something to get away and sadly this was it. Should have stayed here this week as Queensland weather was crap for 4 days. Reminds me of UK weather :)
I see the Telstar made it too!
BTW - Shan are you abusing your moderator powers with that post count :(
id have 2 agree with u there, that forrest has the most wikid roads around
Weee, just got home. Hell of a lot of fun even with sh!t front tyres. Next year need to organise ahead so that everyone knows the way around geelong, so we don't have to go through it :O
Great cruise guys, I had to go back on the first day after Anglesea because it was my brothers birthday, I wudve loved to have gone the whole trip.
So where are the pictures guys, hanging to see all of em!!!
Regards
Kim
Well it sounds like people had a ball out there! Once again another great event . Well done Ash and other organisers.
I hear the Commonwealth Games baton relay was out 12 Apostles way too. Did anyone happen to catch that crowd?
Who invited teh Telstar! along???
Hey
at least he didn't do it on blind corners like other people :O
finally made it home just now :P( my spine is permantly re aligned oh well, i definatly have to do my suspension!!!
cheers to all had great time
big thanks to organisers very well done
will throw some photos on soon as i organise it
tash. mel wants her foto up in members bit if your goin to post it :O and well email me mine and ill email you yours
cheers too all
What an awesome cruise and great bunch of members!!!
One of the most enjoyable cruises i had in a long time, well worth the overnight stay. Will definately be doing it again next year.
Got a few nice pics, will post them up some time this week.
Thanks to ALL, really represented SAU well.
Hope to see ya all again soon.
Alan
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
