Hi all
Which is better:
Blitz Dual SBC Spec S
- 4 boost settings
- single solenoid (rated at 18psi)
- approx 360
Greddy Profec B Spec II
- 2 boost settings (rated at 30+ psi)
- twin solenoid
- approx 400 as well
I wont be boosting more than 12psi, but want something that will hold boost well (no spiking), thats why I am contemplating the greddy even though my boost level is not high.
Anyone used either and whats your experience?
Another one thats also good the greddy profec spec s, I like the turn knob feature that allows you to adjust your low and hi level boost easily. I dont think its as easy with the ones above, or is it?
Thanks all
Edited by nuffsaid
i reckon get the greddy because of the 2 solinoids(spelling) you'll end up wanting more boost than the blitz one offers my mate bought the blitz thinking he wouldnt go over 1.3bar and now wants to raise it 1.6bar
HYBRID ELECTRONIC BOOST CONTROLLER for under $400 - holds boost extremely well.
Here is some further info:
"Hybrid Electronic boost controllers not only spool the turbo up quicker, but also regulates the amount of boost pressure. Features included:- Microprocessor controlled. Closed/Open loop design. Accurate boost regulation. Fast boost attenuation. Two boost settings. Compact Design. Full in car adjustment. Competitve price. 9Bar/130 PSI solenoid. Easy to install with 2 built in pre-sets, easily adjusted by two knobs in the cabin"
I use one and its absolutely fine.... a good choice.
Tangles
The GReddy EBC only has one solenoid.
Are you sure? I thought he B Specs are dual solenoid. A couple of tuners have told me that they are, some links below also seem to think so.
See: http://www.sportcompactcarweb.com/tech/020...boostcontrol05/ and http://www.modernperformance.com/all/greddy_profec.shtml
Arg I'm not sure now - the trader I bought mine off (chiba_osaka_boy) said it was single solenoid and if you look at the size of the Blitz Dual SBC (definitely twin solenoid) solenoid box its quite alot bigger than the GReddy solenoid unit.
Go the eboost 2
get it installed and i will tell you how to use it
you realy need a boost gauge so eboost have 1 is not that much more
and dont do a dyno and i will tell you how to set it
they are so easy to use its not funny
james
It will depend on who fits it aswell
now i can use mine i would say any 1 who knows how to use wat ever 1 you got would be good
tuning is so important
1 tuner over in perth recons that the blitz 1 is the best cause they hold boost the best and are easy to fit
but that was the only 1 they could tune properly i was later told
james
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
