  • Replies 64
Yeah i had the same problem.
Im going to find a cheap(er) twin second hand, osgiken or the like, and then use it until it needs a service then get it back to new. should buy me some time.
But at the end of the day i guess you look at your car and say i want x amount of power, what clutch is up to the task.
rob,
You have the same clutch plate as mine. They need to have a 'bedding in' period. I have no shudder at all, I can take off from idle in 2nd gear without kangaroo hop. You do have a very agressive 2500lb pressure plate tho, makes trying to slip the clutch a bit of an effort over stock.
The pressure plate is something you don't have to go othe top with and in return you get a very stock feel to your clutch, with great grab.
'bedding in' only takes a hundred k's or so. It involves slipping the clutch with a few more revs than normal and not giving it any boot fulls until its done.
If you give it heaps before hand it may take little 'chunks' of material out of the disc.
Yeah he is!!!! My skyline is going in on thursday.... I think Troy is putting his in early next week!!!!
Hehe Ross has soo many cars that he is starting to mix them up :D ... If I played my cards right I could have got Troys flywheel I reckon :)
grrrrrrrrrr
cheeky bugger
yeah mines in on tuesday, i could of done it this week but his install guys father died yesterday so to be on the safe side we went for next week.
$760 to install, my flywheel, 2500lb pressure plate and the 9 button purple clutch plate.
Good price Troy, I think SAU must be sending plenty of work his way, people blowing clutches left and right. Could you ask him if he has any plans to make twin-plate clutches, I think there would be a big demand for them, cause even the 2500lb clutches don't survive big power.
See'ya:burnout:
skyzerr33,
Are you sure you want the 2500lb pressure plate?I'm pretty sure He does a 2200lb which is significantly lighter. Even a 2000lb would be good.
The 2500lb is a leg breaker if you are not used to them. And it's quite a bit of overkill clamp wise.
I agree. I have the 2500pound pressure plate and the thing is a bitch to drive in peak hour traffic. You *have* to rev to about 1500-2000rpm and slide the clutch out (makes hill starts a pain too), otherwise you'll get shudder and the car will bunny hop along. I dont think rev gets this, he has the same 9 finger/puck clutch but a smaller pressure plate.
Originally posted by skyzerr33
grrrrrrrrrr
cheeky bugger
Don't worry.... I wouldn't do that to ya :(
He told me about the mechanic's father also. I fully understand why he won't be in this week but I am taking it to him this thursday still and he said a workshop two building's down can take the clutch out and put it back in and he can still do the clutch work himself. He seemed pretty confident that I would still receive the same worksmanship though. I didn't find out if it is going to cost any extra due to a third party though. I hope not as I only have just enough to do the clutch as is...
I'm pretty sure I am getting the same 9 button purple clutch plate as you too...
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
