any skyline gtst r33 for sale????
buy one from perth!
wat if u dun like the feel of the one from melbourne?
after u already brought it here?
then u would have to either sell it or send it back?
i doubt the owners would take it back anyways!
i heard extreme machines are quite good
adrian :)
Originally posted by trUnkz
hey im deciding to buy a skyline gtst r33...any1 know where i can find one thats in perth???? but if im planning to get it in melb...how much would it cost to import from melb to perth????
Mine is forsale ..
http://home.iprimus.com.au/r_huynh/skyline.html
trUnkz,
Do you want the car to be 'done up' to go quicker or 'done up' to look quick.
Looks are easy. Just buy the one you think looks the best.
If you want the car to go quicker, it is possible the car can be 'done up' the wrong way and you will spend the greater part of your income fixing it back up.
Here are a few tips:
As a part of the mechanical inspection, test the compression both hot and cold. Ask when the last time diff/gearbox and engine oils were changed etc and the regularity.
If the owner claims to have a car that does the 1/4 in any particular time ask to see the time slip. If the owner claims any particular power output ask to see the dyno printout and then totally disregard it.
Check the underside for any evidence of accident damage (Dents in the chassis rail etc. particluar attention to the front and rear).
The most important tip is to test drive as many skylines as possible including dead stock ones so you get a 'feel' for the car and the way it ought to behave.
theres a series 2 gtst with ohlins coilovers,cusco front/rear strut,fujitsubo exhaust,and unisia jecs pod filter. done 64000 ks.but will only be complied in 2/3 weeks. thats the only reason i didnt take it. asking for 26,000. and its at extreme machines
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
