same it costs me more for standard adsl cos i can't get 2+ down in victor.
Thats due to telstra's fee's for phone lines. Not a lot they can do though. The ACCC want them to rent out lines for cheaper than they can afford to maintain them in the interest of "competition"
wooohoooo finally all my nights sitting in front of my PC is starting to pay off. I'm a "silent" partner in a UK media company, We specialize in web design, 3d modeling, graphics and advertising. I mainly do all the 3dmodeling for the company, and am not named on the website (mainly due to the fact i work for a rival company as well :P). The majority (well all) of our customers are involved in Motorsport over in Europe. We have started to sponsor the Roll Centre Le Mans Prototype (rear of the car next to the love heart logo) and the Moore Racing Dodge Viper from the British GT series.
We are also working on a small "addon" for GTR2 of the British GT series with full co operation from all the BGT teams :P and access to all the cars on race week ends. Pitty I can't afford to go over there
unfortunately the majority of work i am doing is all very secret (had to sign 3-4 Non Disclosure Agreements)
so here are a few i have done for myself (so the quality is down on my commercial work)
Edited by Whiplash
I'm not really one who believes in these "pay as you surf" programs ever since AllAdvantage way back in the late 90's early 00's as I did actually get a check from them but this program called Agloco was started up by the same founders of AllAdvantage and seems pretty interesting. Basically they pay you to have a little bar sitting at the bottom of your browser window to surf the net. I recently joined and didn't find the bar too offensive, it's small and out of the way really; of course I only installed it on my test machine just incase but what do you guys think about it?
No, just for surfing the web, they show little ads in the bar that you download, that's about it. Still not 100% on it actually, might turn out to be a crock of shit, but if it is, it's not like I've lost any time on it anyway, would have been on the net regardless :thumbsup:
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
