Usually 2 sticks are marginally quicker & puts less strain than using 4 slots of equivalent memory. Personally, I’d go with any 2GB kit (2x1GB), doubt you’d regularly utilise more than 3GB of memory with your current system.
With the exception of overclocking, there's no real benefit going with faster RAM frequency than what your mobo can support or CPU FSB & in your case that's 400Mhz (assuming you have DDR2 & P4 or better). Although, RAM is quite cheap now so there’s no harm in getting the best 4GB (2x2GB) you can afford, as they are backwards [frequency] compatible & you can always use it in your next system - provided AMD mobo’s don’t also start pushing for DDR3 to become mainstream anytime soon :P.
No madaz it will not.
Your best choice for gaming with a controller on both 360 and PC is to buy a microsoft WIRED xbox360 controller. They are a great controller and work really well on PC.
You can buy the wireless xbox360 controller but then you will also need the wireless receiver.
pkblade when u getting ya 4870???
Finally got it on Tues :D ...went with the MSI's OC version, pretty happy with it so far. Although while I was DL the latest driver I noticed MSI have already released the HD4870X2 OC :). Might wait for prices to go down, currently they're priced $650-750.
So who uses VoIP?
I've been with MyNetFone for quite some time now and really can't fault their service.
Signed up via the MyNetFone whingepool/whirlpool offer. $4.95 per month for 60 free national calls untimed then 10c untimed national and 15c per minute per second billing.
We don't use the phone a great deal but still manage to save a good $80 per month as we often make national and mobile calls.
I'm on the Home Line Budget $19.95 Helstra plan with ADSL2+ from Internode.
For those that are shopping ensure you run a quick traceroute to the sip server you are looking at to ensure the routing isn't stupid from where you are located.
MyNetFone from Internode in Adelaide is ~40ms away with a traceroute you couldn't improve.
Don't buy an ATA device that plugs in to your modem as a lot of modems suffer what is known as a NAT bug; splash out another $40 or so and buy an All in one modem/router/wireless/voip box.
Preferably a billion 740x as they work well and are easy to configure.
i used to use engin for VoIP... service was ok but they were bastards when i went to cancel (having worked in a cancellations call queue with a major ISP i I know whats what with T's & C's, i got his TL on the phone and gave em what for hehhe the dude was highlighted for a "coaching opportunity" LOL ).
I'm also on node adsl2+ wit homeline plus
i had a free zyxel ata that i procured from work.... the GUI is completely counter-intuative on those things
did get delays tho, i tested it bay haveing a mobile fone convo at the same time... it was noticeable
yeah nice work Nick - I remember seeing some of your earlier work on those models and even then they looked the bomb!
Hey Bezender - you need one or 2 of these:
Dual external hard drive case (click)
Benefits
Inbuilt fan - my HDDs stay even cooler than they used to when inside my Matrix VX
Its own power supply
Can take the SuperBox with you and connect it up at a mates place with dual E-Sata for speedy data sharing
One or two of these might be in order too (click)
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
