Usually 2 sticks are marginally quicker & puts less strain than using 4 slots of equivalent memory. Personally, I’d go with any 2GB kit (2x1GB), doubt you’d regularly utilise more than 3GB of memory with your current system.
With the exception of overclocking, there's no real benefit going with faster RAM frequency than what your mobo can support or CPU FSB & in your case that's 400Mhz (assuming you have DDR2 & P4 or better). Although, RAM is quite cheap now so there’s no harm in getting the best 4GB (2x2GB) you can afford, as they are backwards [frequency] compatible & you can always use it in your next system - provided AMD mobo’s don’t also start pushing for DDR3 to become mainstream anytime soon :P.
No madaz it will not.
Your best choice for gaming with a controller on both 360 and PC is to buy a microsoft WIRED xbox360 controller. They are a great controller and work really well on PC.
You can buy the wireless xbox360 controller but then you will also need the wireless receiver.
pkblade when u getting ya 4870???
Finally got it on Tues :D ...went with the MSI's OC version, pretty happy with it so far. Although while I was DL the latest driver I noticed MSI have already released the HD4870X2 OC :). Might wait for prices to go down, currently they're priced $650-750.
So who uses VoIP?
I've been with MyNetFone for quite some time now and really can't fault their service.
Signed up via the MyNetFone whingepool/whirlpool offer. $4.95 per month for 60 free national calls untimed then 10c untimed national and 15c per minute per second billing.
We don't use the phone a great deal but still manage to save a good $80 per month as we often make national and mobile calls.
I'm on the Home Line Budget $19.95 Helstra plan with ADSL2+ from Internode.
For those that are shopping ensure you run a quick traceroute to the sip server you are looking at to ensure the routing isn't stupid from where you are located.
MyNetFone from Internode in Adelaide is ~40ms away with a traceroute you couldn't improve.
Don't buy an ATA device that plugs in to your modem as a lot of modems suffer what is known as a NAT bug; splash out another $40 or so and buy an All in one modem/router/wireless/voip box.
Preferably a billion 740x as they work well and are easy to configure.
i used to use engin for VoIP... service was ok but they were bastards when i went to cancel (having worked in a cancellations call queue with a major ISP i I know whats what with T's & C's, i got his TL on the phone and gave em what for hehhe the dude was highlighted for a "coaching opportunity" LOL ).
I'm also on node adsl2+ wit homeline plus
i had a free zyxel ata that i procured from work.... the GUI is completely counter-intuative on those things
did get delays tho, i tested it bay haveing a mobile fone convo at the same time... it was noticeable
yeah nice work Nick - I remember seeing some of your earlier work on those models and even then they looked the bomb!
Hey Bezender - you need one or 2 of these:
Dual external hard drive case (click)
Benefits
Inbuilt fan - my HDDs stay even cooler than they used to when inside my Matrix VX
Its own power supply
Can take the SuperBox with you and connect it up at a mates place with dual E-Sata for speedy data sharing
One or two of these might be in order too (click)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
