Yeah, I can see more external graphic cards, hdtv tuners and wireless internet dongles on the market utilising this tech. Would be good, however, if there were faster disk drives to take advantage of the transfer rates but by then eSATA III (6Gb/s) or even IV will have been released.
Yeah, I was quite surprised when I saw the new plug type as I'm pretty sure I'd heard they were keeping the same type.
Standard usb connectors have never been to crash hot. the new design fixes a few flaws, namely the snapping of the plastic rectangular guide as well as poor connections due to infirm joints... extra connectors were required for error correction and interleave so they couldnt use the old format. I expect these would be pretty durable as theres no way you're going to jam it in the wrong way (as ive seen some USB sticks done)
-D
surly they didnt need to change the plug type and could of made it backward compatible with USB 2 and 1.1
you guys clearly haven't read the actual article - end A will still be the same physical size of current USB. The pic on the link is for end B.
End A from the full article below:
    • Hi All,    I have my BW EFR 8474 with a T4 split 1.05 rear housing. Rear housing is ceramic coated and drilled and tapped for EMAP take off.  Supported 520awkw at 35psi through the 8HP with ~5k rpm spare on the BW 127k limit. Ran a 9.98.    Turbo is one of the first that was released but only done ~3k kms.    Asking $2800 happy to negotiate. Only selling to upgrade.   Located Gladstone QLD happy to ship.
    • Hi is the Toshiba sceeen still available?
    • Just wondering how come the hood was grinded down?
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is 2050 rpm, going to WOT sees the MAP go +ve very quickly and it has >5 psi by the time it hits 90 km/h. That's still <2.5k rpm, so I think it's actually doing really well. (I edited this from a previous version where I stated 80km/h was <2000, but that was a false memory. If I am rolling at ~1700 in 5th and floor it, it will start making boost before it goes over 2k - which is a separate "experiment" leading to the same conclusion. Which is that the boost threshold is actually quite low. It's not fast there, obviously, but it certainly makes progress towards going fast, which is not what it's been like for a long while!!) Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
