there is a new generation of eeepc's coming out soon called the netbooks
http://www.news.com.au/technology/story/0,...5014239,00.html
that article is a load of shite
EEE's >ARE< netbooks.
-D
Did you two read the article?? :( There's no mention of the next generation Asus Eee PC, rather it was just stating that the Eee PC's was the orignator for the term "netbooks".
"The Eee PC is where the netbook buzz began and remains the lowest- cost entry point...."
lol now that is some real geeky shit right there ^^^^
even geekier is actually sitting up waiting for it to happen.
and worse yet, writing a php script that counted down. lolz
im looking at getting a desktop comp soonish to replace the laptop. im not an uber l337 gamer so i dont want anything too fancy, just something thats gonna handle online games like runescape in HD.
was thinking something like this with the AMD AM2 Athlon x2 5200+. Thoughts and possible upgrades?
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
