after being told it probably isn't worth fixing my laptop, im looking at new ones.
http://www.harveynorman.com.au/products/in...-new-range.html
Looks pretty good for what i use it for, 2.0Ghz Core 2 Duo, 4GB DDR2 RAM, 512mb dedicated graphics.
Why not try and find a replacement screen on ebay and replace it yourself, it isnt that hard, if you dont feel comfortable to do it yourself, i can do it. Replacement screens go for about $150-$250. If ya need any help let me know, i have been pulling laptops apart at work recently as our store has started doing minor repairs.
Unpatiently awaits for the 'decent' 120 odd GB SSD's to drop from the 600+ price range. :rolleyes:
The degraded over time write speeds appear to be sorted with the higher end SSD's via their TRIM/WIPE programs (until Windows 7 that is) now the wait for the price to drop.
cheap ones are inferior to a server card
hence price difference
only because theyre hardware accelerated - which is really only an issue when you're dealing with MAJOR bandwidth transactions (as steve alluded to) or if you're an anal FPS gamer who wants an extra 2 fps (and about a quarter of the ethernet latency - which means SFA unless you're LANning it up)
i think there was a game company making hardware based cards, they were around teh $150 mark for gamer nuts... server cards will still set you back more
IMHO you can't go past the realtek 8139 series if limited to 10/100.... really good driver support and dirt cheap ($7 or so)
-D
I remember an add in some PCPP mags, of a ninja holding a gaming network card....ummmm, was called....Killer. But i don't reckon you would see much difference between a $20 10/100/1000 and a $200 gaming network card for normal everyday use, with a bit of lanning. As for server work, yes i could see a difference there, but why go to that extent for just basic use.
anyone got an external DVD drive I can borrow to install Office on my laptop......the internal one is playing up on this particular disc but the disc is fine on other PC's.
Funny thing is, the laptop plays other discs fine.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
