after being told it probably isn't worth fixing my laptop, im looking at new ones.
http://www.harveynorman.com.au/products/in...-new-range.html
Looks pretty good for what i use it for, 2.0Ghz Core 2 Duo, 4GB DDR2 RAM, 512mb dedicated graphics.
Why not try and find a replacement screen on ebay and replace it yourself, it isnt that hard, if you dont feel comfortable to do it yourself, i can do it. Replacement screens go for about $150-$250. If ya need any help let me know, i have been pulling laptops apart at work recently as our store has started doing minor repairs.
Unpatiently awaits for the 'decent' 120 odd GB SSD's to drop from the 600+ price range. :rolleyes:
The degraded over time write speeds appear to be sorted with the higher end SSD's via their TRIM/WIPE programs (until Windows 7 that is) now the wait for the price to drop.
cheap ones are inferior to a server card
hence price difference
only because theyre hardware accelerated - which is really only an issue when you're dealing with MAJOR bandwidth transactions (as steve alluded to) or if you're an anal FPS gamer who wants an extra 2 fps (and about a quarter of the ethernet latency - which means SFA unless you're LANning it up)
i think there was a game company making hardware based cards, they were around teh $150 mark for gamer nuts... server cards will still set you back more
IMHO you can't go past the realtek 8139 series if limited to 10/100.... really good driver support and dirt cheap ($7 or so)
-D
I remember an add in some PCPP mags, of a ninja holding a gaming network card....ummmm, was called....Killer. But i don't reckon you would see much difference between a $20 10/100/1000 and a $200 gaming network card for normal everyday use, with a bit of lanning. As for server work, yes i could see a difference there, but why go to that extent for just basic use.
anyone got an external DVD drive I can borrow to install Office on my laptop......the internal one is playing up on this particular disc but the disc is fine on other PC's.
Funny thing is, the laptop plays other discs fine.
    • Hell yeah. Glad to see it’s closer to the road.
    • Thanks Brad Sheriff. I think he single handedly made the price of NEO heads rocket to the stratosphere.
    • Oh ok that makes so much sense. Thanks for clearing it up!
    • And these modern "environmentally friendly" EV vehicles also run on the same smoke! When the engine, wiring, or batteries let it escape it also stops running!
    • Yeah - I found the same information too.. 30% open is like 85% of flow etc. So it's probably going to be minor if not completely imperceptible. I also have a larger pod filter here, will swap that on and see if there's any difference. The hardest part is finding a place to uh, test this. It's quite noticable just how much having ducting to the otherwise completely open pod cools the intake temps down. It's better boxed, or shielded but driving for 30 seconds really makes it plummet to near ambient temperatures. I recall in the past when I was a RB land and had a nice flowing airbox -  - Then I took the lid off and put a pod there, and gained 9 psi of boost and about 60kw from the restriction I didn't know I had - with the controller at same duty cycle. However finding people using over the radiator intakes having similar KPA drops at WOT on built setups makes me think there restriction could be the exhaust or potentially the headers. Either way though, there's no real estate to play with and nothing that can realistically be done about it. The original dyno plot without the airbox, and the larger pod had a better curve. It was later I added the ducting and airbox, and a smaller pod to make it fit in there...
