but everything I ever buy is overkill, lol.
well have i got a new car for you.....
I can finally work on models with out the PC freezing every 2 mins when you click on a pixel
previously the 3d work was around 50K poly now working on 200-300K poly models
which look sooo much better when doing 19,000 X 10,000 renders :cheers:
Edited by Whiplash
hi all.just wondering what you all use as a media player on ur PC?
i use VLC, love the layout and most things about it. the issue i have is it freezes over the lan, and also on my desktop... i have used the googleizer and tried the things suggested there, increasing the buffer helped a lot, but i still get the freezes :)
in the past i was a big fan of media player classic, but i find the playlist a bit clunky so i have been persisting with VLC.
does anyone out there use anything else that is worth a shot?
...::edit::...
my os is win 7 ultimate
Downloading VB 2010 Express at the moment (http://www.microsoft.com/express/Downloads...10-Visual-Basic). I remember using this years ago, I'm willing to have another play around with it to see what it can do.
Carl give ZPlayer a try ..... I use if for watching DivX movie/tv dls and it works a treat. Seems to handle different file types and codes better when doing fullscreen than all other apps I have tried. I also use the CCCP ffdshow/codec pack - has always been great.
guys I've got an old Benq laptop that does pretty much everything that I need for work.
Except for a little more speed, I'd be happy to stick with it for another year or 2.
Thing is, it has an IDE HDD (not a SATA) so going to an SSD to improve performance is pretty much out of the equation.
Anyone here ever configured an SSD into an IDE connection?
Depends on if you have 1.8 or 2.5" PATA drive;
http://www.solidstatecentral.com.au/store/...8b79bfa4f8f3fc6
I've bought runcore SSD"s off these blokes before and used them as upgraded drives in EEE's. Work very well.
-D
The transfer rate of IDE wont give you any decent performance with a SSD over the normal drive. But if you are keen on the SSD idea still, you could use an IDE to Compact Flash converter.
this is what I'm worried about........if the controller is the limiting factor then it's probably pointless spending $300 - $400 to gain little if any speed at all......better off puting it towards another laptop maybe.
This is what's in it now:
WD1600BEVE Scorpion Blue
160Gb 8 Mb cache 5400rpm 2.5" PATA
the transfer rate will be a sustained rate rather than a variable rate and there will be no seek or write latency
you'll notice the difference. put it this way, ATA supports up to 133mhz bandwidth, SATA is 150... SATAII 300... etc
diff between sata1 and ide is not much at all - esp since your drive is a 5400rpm its slow as dogs balls...
the other benefit is the wd probably runs 5watts when seeking and reading, the ssd will be about 0.1watt peak. You'll save a fair bit of battery with an SSD..
-D
you reckon the extra minimal performance difference is worth the dosh though?
Wish I had some figures or comparisons between my drive and an SSD on an EIDE controller
for the price? frankly no.
buy a new laptop with an ssd already in it, if you want the bang for buck
however ssds will speed up ur system, including outdated ide buses
-D
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
