Long file names in folders upon folders upon folders f**ks up everything.
Had a dude with a file that was like a sentence, which he put in like 40 sub folders... Oh god. That was a nightmare.
try tell that to the doctors and nurses mate.....they do that all the time....trying to fix something that they have "lost" is impossible lol
Abe, do you get many SSD's coming back for warranty claims?
None, as we don't stock them, as they aren't main stream yet, however we can order them in for you, but warranty would be a real pain.
WTF - SSDs aren't mainstream? Given they have been commercially available for nearly a year and MSY sell out every time they get a shipment in, I would suggest otherwise.
I can however understand all PC shops not wanting to stock them - suddenly all the pos 3 year old PCs that are now a bit slow are sped up significantly with the addition of an SSD drive. Millions of people worldwide will not need to upgrade for another X years due to how much faster they make a PC. Even an old single core XP4000+ absolutely flies with Windows 7 on an SSD.
Oh yeah, I have some PC gear up for sale too guys: 1 x Acer core 2 duo 2 x 1.86Ghz CPU, 1Gb ram, 80Gb SATA HDD PC with 17" LCD $300, Brand new CD Burners (NOT DVD) $10, 8Gb Sandisk Extreme III CF Card $40, 19" AOC CRT monitor $50, brand 1.5 inch photo frame with internal memory $10
They purely aren't mainstream yet, they are still in their infancy as they are still trying to get better access times, price to gigabyte is shocking, they are purely for performance enthusiasts at the moment, until they become better priced per gigabyte.
Kingston SNV425-S2/64GB = $270
Kingston SNVP325-S2/64GB = $331
Intel SSDSA2MH160G2C1 = $933
Seagate 500gb = $85
WD 640GB 64mb Black = $121
WD Raptor 450gb 32mb = $448
WD Raptor 250gb 16mb = $240
As you can see, price to gigabyte, SSD's are not mainstream, UNLESS you are going for performance, then they are for enthusiasts.
anyone know who is working @ modbury IT warehouse with a black R34
I do :D, I found out today but ringing up and asking, lol. The owners name is Michael, he used to work at the Blair Athol Store till it shut, and used to drive a Silver one apparently, now drives the Black one. Other then that I don't know too much, as the person I spoke too doesn't know too much about cars, all they know is they use petrol and brum.
I do ;) , I found out today but ringing up and asking, lol. The owners name is Michael, he used to work at the Blair Athol Store till it shut, and used to drive a Silver one apparently, now drives the Black one. Other then that I don't know too much, as the person I spoke too doesn't know too much about cars, all they know is they use petrol and brum.
i think abe misspelt it :D get rid of the "r"
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
