that is an awesome setup.....but i am with you on this Andrew....water and electrical components dont mix :)
water cooling is only dangerous when you use water ;P
there are proper coolants available that are non conductive, as well as all-in-one premade units like the corsair cpu cooler found here
http://www.pccasegear.com/index.php?main_p...oducts_id=12235
which i have used on several of my recent builds - theyre awesome...
otherwise, you can completely immerse your components in an inert solution, such as here :
http://yourtech.typepad.com/main/2008/10/l...right-here.html
one of the earliest examples of this they used canola oil - which obviously isnt great to get on components as its thick and a pain to remove off components - the proper coolants evaporate like alcohol once components are removed from the solution bath
its good stuff, but way expensive for the most part
-D
Thats a sexy piece of hardware I reckon... pity about the price.
quite pretty but there is a good reason the cost is so high, and that is the atx connector backplate at the rear of the motherboard - sealing that section off to stop leaks is pretty difficult however these guys make their own gaskets and use a brace to keep the pressure on the case
incidentally some mainframe/datacentre computers are 100% immersion watercooled because of the huge amount of heat distributed from all the cpu cores
gonna buy that very corsair water cooler next fortnight - hopefully this coming summer it'll be sufficient to keep my system totally cool
-D
Firefox is giving me the shits.
Go do add this theme: https://addons.mozilla.org/en-US/firefox/addon/64006/
Tells me i am using 3.0.8, go to help, about firefox, says version 3.6.4. Tried restarting, no good. wtf? do i uninstall and reinstall?
Some help required lads, my sis tried to connect to the net the other day only to have firefox chuck up a message that it was configured to use a proxy server that was not allowing connections or some jazz.
I went into internet options and selected 'auto-detect proxy setting for this network' so i can go on the net, just wondering if I should leave it on that or will it be (more) vulnerable to attacks/people fking with my pc, or could that even be the case as to why the error came up in the first place?
Only tick it if she's running a proxy server... which I highly doubt unless the PC is in a business location.
THat option on or off wont change anything to do with people attacking it.
Excuse me ladies and gents.
It's not so much computer oriented.
Do any of you know how to make my LG BD560 blu ray player region free? I remember doing it for my old LG dvd player years ago. It was some code I had to enter in.
I am having trouble finding anything about unlocking the region code on the net.
Any help would be fantabulous. PM me if ya can.
Saves cluttering up this thread with my useless shiznit
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
