iinet 150gb business plan here .. expensive, but I have a public IP range routed and all sorts of other nonsense which none of the other providers will do at a remotely reasonable rate.
I'm roughly 4km from the exchange too - syncs at about 7mbps..
^^^ Pfft I dream of that sort of speed - I live in Northgate (a whole 7km North-east of the city), I am under 2km cable length from my exchange, yet as the whole of Northgate runs off a RIM we can't get ADSL2. I am stuck with a crappy 1,500 connection and pay a higher plan fee for the same amount of data vs a faster ADSL2 connection - go figure.
Didnt Northgate get fiber through Internode?
I find the Microsoft Security Essentials to be a great low resources and reliable antivirus sytem
Link: http://www.microsoft.com/security_essentia....aspx?mkt=en-us
Thats what I use - it aint bad at all
Northgate is on a rim - you're thinking of Lightsview/Lightview which is adjacent - and is still being constructed
-D
    • Hi guys, thanks for the replies.  I will have to wait till summer to test properly, but it short cycles both when heating and cooling. I’ve ordered a new internal temp sensor that sits under the vent in the steering wheel also, GTSBOY, I have an Apexi FC ecu, I’m assuming I won’t be able to diagnose or would it still work? Could the ecu be causing the problem??   the pressure switch is quite cheap I will get a new one and try it out, hopefully it doesn’t require purging the refrigerant again?
    • Do you know what size restrictor? Just flushed it with the Prestone flush & then water numerous times until the water ran clear, still looks rusted & will no doubt cause trouble later.
    • you can enter your VIN (the original, japanese one) here to find the correct part#: https://www.amayama.com/en/genuine-catalogs/nissan however, after all this time it is more likely to be a wiring issue than the sender
    • no, it was the same here, just flurries but no need to get the toboggan out....but it is exactly the sort of days where its good to have some inside jobs on the list. Speaking of which the fuga is driving properly after 2 1/2 years.....but that is a whole other thread
    • And yes, put in the restrictor while you are there; a standard engine is fine with a little less oil and you are less likely to run out of oil if you have sustained high revs for any reason eg visit a track one day. How did you clean the cooling system
