i read for the R33 when i had mine, that the fuel light came on when there was approximately 7L left in the tank. one could assume the same for the stagea. i've driven for up to half an hour on my fuel light and not had a problem. helps to squeeze that little extra out of a tank
  • Replies 216
i never really bother. Under 1/4 and i fill up.
When installing the fuel pump, i was told the fuel tank design is different in the stagea in that there is a little "pocket" in which the fuel pump sits, meaning it is 100% the lowest point in the tank.
Ive driven around 2 days (~50km) with the light on and my 040 was still able to suck fuel up
couldnt agree more tangles
i filled up $91 the other day.... 66L... yepp... I KNOW ITS A 65L tank :D
Dunno how many litres but $68 for 98/10 from when the light came on.
Currently using 15or16/100.
Would like toget a kickback from AWB.
ok, first re-fill, some very varied driving including some babying (while I had an exhaust manifold leak that sounded scary) some highway cruise, on most drives I managed give it a poke in the guts once or twice, and one rip through a very twisty section of the Ocean Road late one night mid week after I fixed that manifold leak...
390km/51Litres
~13L/100KM
Not bad, I think it could do all right on a long open road trip, filled up with a bit under 1/4 of a tank and got the 51 Litres in so there was ~15L left if it is a 66L tank, that would have been close to 500km to a tank, that sounds all right to me.
I try to fill up around the 1/4 tank mark as it doesn't hurt so much, just more often I guess...
Cheers
Luke
revving on the hwy is the fuel comsumption killer
its cycling through the load axis on the fuel map that waste's fuel.
as soon as you open any decent amount of throttle it will drop on the load map on the stock ecu and the afr's will richen up too all hell, which is where the economy goes out the window
if you do a full tank of 100km/h driving with a steady throttle you'll get some kick ass economy, assuming the narrow band sensor and 02 feedback is working correctly
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
