  • Replies 216
Well I did an 'economy run' recently in my stock S2 stagea, keeping off boost where possible and I got 12.8L/100km, measured using the method in the above post. I like to reset the km's every time i fuel up so I can work out my fuel economy.
Driving how I normally do I get between 13.5 and 14L/100km (city driving, mostly peak hour traffic) and the above figure included a fair bit of driving outside peak hours so its a little bit optimistic.
Not that much difference between the two figures though which I thought was great because it means my usual driving style isn't costing that much extra in fuel. I'm not a leadfoot but I do like to boost a bit when accelerating.
just an update on my own post from a few months ago...
I now get an average of 12.5L/100km city driving, that is, not driving economically. So thats 1-1.5L/100km improvement thanks to a combination of turbo, exhaust, and safc. :wave:
Not sure how much difference each mod has made (with regards to fuel economy) but I'm pretty happy with 12.5L/100km. :P
Edited by pixel8r
oh ok thanks for that, yeah im not sure if mine has been modded in japan or something everyone says it has more power than other stock skylines they have been in, plus its an auto.
also i see you have marked that u got 150kw
i think mine has 195
is that my problem there??
i dunno wats going on
it even leaks petrol fuems ot the petrol cap fromt he side of the car heavily someetimes/
Just drove from Rocky to Brisbane, ~700kms and got 610kms out of my absolutly full tank to when we hit the light, all basically done in 5th with little to no boost and NO overtaking whatsoever and spent between 80-100kph.
Better then my mother-in-laws VS wagon did when she did the exact same trip :D
Congratulations, you just convinced my dad. Oh... wait... 5 speed... dammit...
maybe ill have to get some more money and get a manual
  • 4 weeks later...
okay im shit at maths so can someone do it for me?
1685kms trip (vic to qld) at an average of 90kms in a series 2 4 speed...
what kind of petrol consumption would this take? im pricing up delivery vs a cheap plane ticket and driving the car back...
hard to say but mine is doing about 11 litres per hundred on a trip that would work out around 154 litres of fuel at say roughly $1.25 per litre depends where u buy it so id recon $191.50
Went to the in-laws over Xmas. They live in in a new house which requires travelling over a fairly steep, twisty road. Travelling there the wagon got 11.6l/100km. Hills make quite a difference to the economy. Every time you power out of a 35 km/h corner the auto drops into 2nd and puts you right into boost.
Other than that, I drove at 100-110 and nailed it a couple of times to pass slow cars (and to test the engine after getting the mis-fire fixed).
holy crap i only get 250k to whole tank 300k if im luky any ideas on what i should do to fix this problem up
its an auto as well
it has some balls over other stok skyliens so i guess its been worked bigger injectors or something.
its giving me shits cant afford to drive it nowhere.
and what can u get on a whoel tank.
do u run premium
its an auto as well
do u run premium
hmmm errr try typing a few helium ballans onto your lead footed!! LOL :happy: that might help a little. It also largely depends on your driving style as well.
  • 1 year later...
I may be wrong, but Caltex fuel seems to be giving me significantly more power and
better economy (100 ks / tank extra) than the Shell that I have been habitually using.
This may just be my engine, it may be the M35 V6?
I've just filled up again and will monitor the usage.
Has anyone else experienced this?
M35 owners - have a try and let me know what you think
mm
Strong advice after lots of nissans - NEVER put anything except the shell or BP fuel in them! :)
Ian
mm
Strong advice after lots of nissans - NEVER put anything except the shell or BP fuel in them! :(
Ian
Nope. In the rare instances I have actually used Caltex fuel, it has given me no better economy nor power than Shell Vpower or BP Ultimate.
I have also been told that Caltex is a "dirtier" fuel... whatever, I didn't really use it before hearing that so.....
Having said that, what are the differences with your car? Economy numbers? Power description?
.... And I never use Mobil.
Edited by iamhe77
quit your winging , when i bought my car we had to pay $2.30 a litre for bp 98 (NZ). mine did 420 kays from half way between full and 3/4 down to bang on 1/4 . did 120kays the whole way and passed everything i could find. included finding the speed limiter
Hard to quantify. Last tank gave me 12.5 l / 100, previously its been more like 15. 570 ks per tank vs 450
As I said, I'm trying the 2nd tank now.
As to power, this is seat of the pants stuff. I'm comparing with my 200kw ATW zxtt. Still not as fast, but noticeably better than it was.
m
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
