Well it turns out my leaking raditaor/hose is actually my welsh plugs in need of replacement.
A fairly cheap part that requires the manifolds removed to replace.
Thanks for the quick diagnosis Dan.
Any one in Brissy had these done?
Whats the labour time in pulling the Turbo off?
Mud
https://www.sau.com.au/forums/topic/109298-welsh-plugs/
Half a day to get at them....half an hour to replace them...half a day to put every thing back.
You need to know if there is one in the rear of the block..cos if so you need to remove the engine or cut a hole in the firewall.....good luck
https://www.sau.com.au/forums/topic/109298-welsh-plugs/#findComment-2013358
Most mechanics can do this. I had mine replace when my engine was built. It depends if you are going to replace them all or just the leaking one (best to replace ALL that you can GET too when replacing the leaking one).
Get some quotes and see if dan is available. If its around the head then most likely a head removal will be required = expensive and off the road.
Jay you should NEVER cut the firewall to change a welsh plug...
https://www.sau.com.au/forums/topic/109298-welsh-plugs/#findComment-2013734
I'd just take everything apart yourself - and get a mobile mechanic to replace them. It's only nuts and bolts. Just time consuming to get them all off. Will save you hundreds.
And once you've done it once, it's much quicker the second, third, fourth, etc times :)
https://www.sau.com.au/forums/topic/109298-welsh-plugs/#findComment-2014026
Hahaha!! I did that many years ago to my Mk2 Jaguar, Try removing a 3.8L straight six from a Mk2 by
yourself with minimal tools nil workshop gear and working in a dirt floored ex chicken coop :)
These days I would of course take out the engine and replace ALL the welchplugs.
It continues to surprise me that people are forever asking where they can get replacement parts
especially odd bits like welchplugs
Hint!! you are driving a NISSAN vehicle :O
https://www.sau.com.au/forums/topic/109298-welsh-plugs/#findComment-2014094
So who has them?
https://www.sau.com.au/forums/topic/109298-welsh-plugs/#findComment-2014166
Sigh! Try your nearest Nissan dealer you will need your VIN number
I think most of the bigger Nissan dealers now have the CD and someone who can find parts in it
I have found Nissan in Lutwich Rd Windsor...just down from the Royal Bris Hosp. to be very helpful and they will get stuff in from Japan if needed.
https://www.sau.com.au/forums/topic/109298-welsh-plugs/#findComment-2016158
yourself with minimal tools nil workshop gear and working in a dirt floored ex chicken coop :cool:
Hint!! you are driving a NISSAN vehicle :P
But $10 thats how the jag repare manual would have said to fix the problem!
https://www.sau.com.au/forums/topic/109298-welsh-plugs/#findComment-2016243
in the old Land Rover I just got the drill and drilled a hole in it and popped it out with a screwdriver, you should probobly not do this on the skyline as metal shavings could get in the engine, but if worst comes to worst.
Putting them back in was a bitch, make sure that you get areas very clean from rust and grease. I used some Extreme Temp gasket goo and applied to to both the Block and the Welsh Plug, waited till thay bacame "tacky" and then tapped them into place with a similar sized socket.
I am not saying that this is the correct way, but it worked for me and got me out of trouble (I was actually 200 Kms from home when this happened).
Chris
ps... Make sure that you get Brass Welsh Plugs.
https://www.sau.com.au/forums/topic/109298-welsh-plugs/#findComment-2020195
who built your engine and where did they get them from??
https://www.sau.com.au/forums/topic/109298-welsh-plugs/#findComment-2049984
i'll find you a part number tonight mud..
unless you go there with a part number, they're f**king useless
Kewl,
Local mechanic quoted me a days labour to change em, 350 - 400
Mercury 650 - 700.
Might have a go at pullin some shit off this weekend.
Anyone wanna help?
:cough: Gordo, Jay, Dan :cough:
https://www.sau.com.au/forums/topic/109298-welsh-plugs/#findComment-2050635
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
