  • Replies 283
Posted Images
Here's two of my favourites..
Had alot of fun guys, hope to do it again. With even more of you, and next time I won't walk off to get a burger...before we line the cars up to take shots... ( didn't know lol : )
My mistake...
im exhausted from the cruise......but IM HAPPY!!!!!!! The cruise up newcastle was kinda lonely, thank Jon (primordial) for keeping us entertained on the cb.
Just wanna say hi to everyone I met there, chances are I've forgotten you name already, but not the face. And a big thanks to Jeff for organising this cruise.
Alien, stop slacking around and get them 400 pics up :whistling:
saw you drove pass me around horsby area.....I was stuck in traffic
also saw a whiteR33, silver R33 and a R32 on the side of the road around berowra, didn't know who they were, too dark to see, but gave a beep and a wave. :whistling:
Edited by lingeringsoul
hi all nice turn out 2day
i got quite a shock how many cars actually made the trip
i've got some pics to post up just need to upload them first
it was good to meet some new people
maybe next time us newcastle people can organise a cruise down to meet all you sydney guys..
also saw a whiteR33, silver R33 and a R32 on the side of the road around berowra, didn't know who they were, too dark to see, but gave a beep and a wave. :bunny:
ohh!!!! so you're lingersoul! LOL!!!! :) it was us you saw regrouping and having a chat after the old pac :(
oi! you bastard, thought i woundn't see this didn't ya!
a no show by you too!
He showed up :)
All the rest of you Sydney kids had left before they got there, though...
A couple of us stuck around for a bit longer :(
He showed up :)
oh! lol
We ccame back to that car park at about 4.30 and there was just a few people left!
must have missed him!
oh! lol
Whoa :)
They can't have stayed for long then, 'cos we left at 4pm.
They were all there when we left :(
Where did you guys go?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
