Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Originally posted by 87vlt
So that means he's more than likely not running the stock boost either .... as by having less restriction you boost increase .... so really its not a good indictation for stock reading .....
yer good, yer another ****ing dickhead attacking me again
your right man, i wouldnt have a clue cause my boost guage says 7psi and it doesnt waver till later in the rev range for 9psi, once it hits these marks it doesnt move, mabey i should throw it out
its a ****ing catback u tool, thats it, the boost does not spike, jump or whatever, but then again what the **** would i know, its not like i have a clue what the **** im on about, there is no ****ing bleed valve, there is no punched out cat or dump pipe or anything, yet im running 14.1, so mabey willowbanks timing gear is ****ed too, got anything else to blame it on?
you ****ing got up people for raggin on your car, your no bloody better yourself you jerk
dont be:)
well everyone has their diff point of view
just do whatever is rite and u feel like then is ok
cant always mind what others think about ya
u will have a hard life:)
cheer up...dont be depressing...to make u feel better
i just totalled my skyline 32 on this Monday and now injured sitting at home with scar on 1 eye...i can overcome it:)
why cant ya with the comments from others:)?
live happier:)i am sure u can
ugly ?
why say that?
everyone has their pretty side of them..u just need to reveal them to public... no1 is ugly if they have a kind and nice heart
thats what counts...not on the face, but in the heart:)
i work too! u can always be happy at work and off work..coz there is just so many things interesting happening around...u just didnt take notice of it thats all:)
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
