Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
I wish I tried harder in school. Now I work I realise how good it was to just bludge and sit down all day listening to other people talk utter shit from 9 - 3. OH.. was I meant to be listening to that crap?? OOOoops :D
Well.. I gotta work to keep my car, that's all that keeps me going :)
I'm not really a big fan of that hey :|
Maybe if it was in a different colour. That chamelion paint, if you start mixing too many colours together all you get is brown/gold. And theres a lot of gold in that.
If I was ever going to spend tha tmuch money on a paint job like that, I'd rather get purpleen or something. Only two colours :(
Anyway, personal choices I guess :)
Guest 87vlt
Originally posted by MM2death
This is one wild 32 GTR...down at a car show on the coast the other weekend.  I remember seeing at dmd the image about a month ago...it got painted there.  Apparently the owner is from townsville.
:whackit: thats awesome. so how is everyone on this fine tuesday morning? Man this 5 day week is going to kill me!!!
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
