Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Erin basically paul gave the sample of the SAUWA shirts away to a friends girlfriend - but we the supplier needs the sample to make the shirt - because we rushed the order thru it was the only one he had - now we ar epissed at paul for giving it away - besides its the only white shirt n black ones and why couldnt she have waited like everyone else.
So i stuck up for my friend who was organising to have the shirts made cos she was pissed and so am i and paul doesnt like it cos he reckons he did the right thing in not consulting any one and taking upon himself to give the only sample away - its making it difficult for the other shirts to get made and holding it up.
Im going home
Paul i'll say it once i'll say it again u have no clue.
Guest neoGT-25
well... im in some trouble... i found a 2000 R34 GTT in white with c-west kit, no spoiler, lowerd, exhaust system for $36,000 so i want to sell my car and get it but i dont want to sell my car... why cant money rain down on us :)
its so irisistable!
tell me what i should do ;) the insurence will kill me (even more) but its so damn hard to choose :(
Neo, I don't think you should do it.
I think you should learn to drive the N/A first then step up to a Turbo..
Not saying your a bad driver but you know what I mean. Young guy gets in fast car, shows off to mates.. finds power pole.
I seriously think you should learn how to drive a sports car properly first and then upgrade, otherwise you'll kill yourself.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
