Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Originally posted by NismoGirl
They've probably got some good cruise organised or something :P
Mixture of the dino cars at Wanners , cruise to the hills and kicking back enjoying a glorious , sunny day in paradise...
Cheers
ken
Originally posted by Boxhead
looks like ken wasnt invited hehe
But I was.
I did the family thing and saw me Mum.
Now I am back with my friends ( well friends except you Boxy ):bahaha:
Hehehee
Cheers
Ken
Was told by Micko that Zanda , pwptpf , hisself and Caminperth were there and cruised.
Niz ( down erin , down !) was there but went home cos she ain't got no good rubbers.
That's tyres for the dirty minded:D
Cheers
Ken
Just taking the piss Boxy.
Yea , it's like people with snot nosed brats who run riot and then say that there little johnny has ADD.
I tell em it's LOAGT
( lack of a good thrashing )
Cheers
Ken
Guest Boxhead
hahaha yeh thats it, too many people are coming up with these bullshit medical conditions.. i should come up with one so i dont have to work,
oh wait they have it already, its called chronic fatigue, or as i call it
L.A.Z.Y...
i admit im lazy, but im not dishing it off to chronic bullshit
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
