Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
yeah well i get like that sometimes and if it wasnt for this one dude at work i wouldnt have made it this far i dont reckon or maybe i would have but i would be majorly stressed out and would have probably punched a whole in the wall or something by now. Its gets stressful skinning your knuckles all the time and hitting your hands up against sharp edges
yeah, well today i was contemplating whether i want to do this or not?? Just jobs that piss u off that arent as easy as it seems. Especially when the tradesman give me shit coz i aint as quick as them. Well i am not going to be as quick as them in my 1st year but that doesnt matter to them. I mean alot of the time they were just ganging up on my as a joke but that shits me more. Like i ask for a hand ans they start clapping and saying good on ya mate yeah. thats annoys me alot. But u get over those things i guess even though i aint fully over it now but after a good night sleep and afew rums i more than likely will be
lol. yeah well u will meet alot of those dreamers in live and i will also coz im 18 so still got many years ahead of me. But life sucks sometimes aye. But u keep at it and it gets better. Like on wednesday it will be better for me coz thats when i pick up my new car. Hell yeah. So until that day then it will continue to be shyt
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
