I'm trying to get my head around this 6 stroke engine. Correct if I am wrong:
Stroke 1: Induction
Piston moves down, sucking in fuel and air through the carby
Stroke 2: "Primary" Compression
Piston moves up, compressing air and fuel
Ignition:
Fuel is ignited as piston approached top dead centre.
Stroke 3: "Primary" Expansion
Burning air and fuel expands rapidly, pushing the piston down.
Stroke 4: "Primary" Exhaust / "Secondary" Compression
Piston moves up, driving out exhaust gases. Unlike a traditional engine, the aim is not to remove all exhaust gas in this stroke, but leave some hot gases present. It was mentioned in the article that he was experimenting with not letting the exhaust valves open at all druing this stroke! The remaining hot exhaust gases are compressed in this stroke as the piston moves up, increasing pressure and hence heating it up
Water Injection:
Water is injected into the chamber with the super hot exhaust gases, causing it to boil and create steam.
Stroke 5: "Secondary" Expansion
The water boils, rapidly expanding into steam, driving the piston down in a second power stroke. As the gas boils, heat energy is absorbed from the surrounding environment, effectively cooling the engine.
Stroke 6: "Secondary" Exhaust
Piston moves up, driving out the remaining gases through the exhaust valve.
Rinse and Repeat.
The advantage of this engine is that it has two power strokes for every 3 crankshaft rotations. This should give increased engine power over a four stroke engine, which has one power stroke for every two crankshaft rotations.
Almost like two stroke power levels with better economy than a four stroke!
The cooling effect would allow increased compression ratios, or more turbo boost pressure for skyline fans, without the need for higher grade fuels. Potentially, it could remove the need for an intercooler in turbo cars, greatly reducing losses through the induction system.
Additionally, one of the power strokes uses water for power rather than fuel, so your fuel bill will be divided into half water, half petrol, and obviously water is a lot cheaper than petrol and will hence save you money.
https://www.sau.com.au/forums/topic/109772-6-stroke-engine/#findComment-2024480
Yeah he wont be around for much longer......as in the Gentleman who made the Delorean.....Stainless Steel Panels = Drives panel beaters out of business, so he got a good talking to.
As in the people who made the Ceramic engine (EXTREMELY efficient).......that didnt go into production.
Or the various back yard projects which have had Hydrogen engines etc etc, fill it up with your graden hose and a wayyyyy you go.
All these things have been thought about and done. They dont see production because of the big business's sending goons after them.
If you guys dont hear from me again, you can have my Charade..............only if you plaster it with GTR badges though :)
Edited by Dingo
https://www.sau.com.au/forums/topic/109772-6-stroke-engine/#findComment-2024919
If you guys dont hear from me again, you can have my Charade..............only if you plaster it with GTR badges though :O
Hey man - Paranoia is an UNJUSTIFIED belief that people are out there trying to get you. John DeLorean was actually set up by the FBI - true story. That his car company was dodgy, did all manner of illegal sh!t & was always headed for disaster is a whole other conspiracy, er story. By the way Colin Chapman is alive & well & living in South America. I have it on good authority the Ferrari's recent about turn in form is due to some of his consultancy work.
Oh, yeah you forgot to mention that the real reason Kennedy was assassinated because he told Marylin Monroe the truth about the UFO's......
Gotta go, someone is watching me. :)
https://www.sau.com.au/forums/topic/109772-6-stroke-engine/#findComment-2024990
Stroke 1: Induction
Ignition:
Water Injection:
Rinse and Repeat.
The secondary power stroke is not going to have the same power as the primary one though so you may have balancing or harmonic issues unless there are a lot of cylinders, like 8 or more.
https://www.sau.com.au/forums/topic/109772-6-stroke-engine/#findComment-2027903
Gotta go, someone is watching me. :(
Ahmen Brother! :(
Paranoya nothing man! He lives!!
Edited by Dingo
https://www.sau.com.au/forums/topic/109772-6-stroke-engine/#findComment-2028968
The steam stroke would'nt have as much power but in a 6cylinder it would harmonise well. I wonder if you would do without cooling though as its not just combustion that generates heat, electric motors and gearboxes get hot too.
https://www.sau.com.au/forums/topic/109772-6-stroke-engine/#findComment-2029197
not neceserally sky
think bout water injected cooling systems
water is directly injected into the air intake to cool it down
compression ratios are turned up for the loss of fuel(or down i cant remeber)
and it is all honky dorry
https://www.sau.com.au/forums/topic/109772-6-stroke-engine/#findComment-2030147
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
