  • Replies 72
I just got my R32 GTST insured with justcar. Valued at $11500, excess is about $1500. im 20 with no previous crashes or claims with a rating of 3.
I pay $1562 a year. All they listed mods where spoiler and exhaust, no stereo nothing else.
Shannons wont insure car without a locked carport/garage. They also charged me $4500 a year comp.
No other companies will insure an under 25 import car driver. My old mans broker rang them all.
Does any1 know with justcar if ur car is a write-off are you able to keep the car?
  • 3 weeks later...
Sup, Im 22 and I just start with just cars with the 32 i just purchased. I have mentioned I have lost my license prior and the car is modded:
Metal Head Gasket
all internals upgraded
2 extra injectors
Front mount
Oil cooler (braided lines)
Greddy BOV
GTR Radiator upgrade with copper core (new)
M's Pod Filter
JUN piggy back computer
Greddy Rebic
HKS Boost controller
3 omori guages and one blitz
Heavy Duty clutch(new)
2 way mech LSD
Tein Coilovers
Tein adjustable castor rods
Strut braces front and rear
B-pillar brace
Sway bar upgrade
Trial Wheels
HKS turbo back system
Nismo Gear knob
alarm
Gearbox has been upgraded (by JUN)
sparco evo fix back
HKS turbo timer
Geniune Veilside pod mirrors
3 point Harness
Power Steering pump replaced last week (these seem to go on older lines)
Clear indicators
Kenwood H/unit
Cusco E-brake button
Full comp with rim included $1008 for the year. not to shabby.
Holy Crap, I just got my renewal from Just Car and its pretty damn good, I didn't expect this at all.
I joined with them last year and paid $2200 for a year and I thought it would be similar around the $2000 mark, nope, $1175 for renewl :angry:, I was stoked. Thanks though to 8005TED for quoting me from Shannons but I had to stick with Just Car >_<
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
