Hi guys,
I need some rear speakers for my r32 , and i dont know shit about car audio.
At the moment the car has a KENWOOD kdc-mp4029g headunit installed , and some 4x6 JBL gto6426e speakers in the doors. Now what rear speakers would be good? JBLs again? Also i will need an amp right? How many channels etc. I dont care about putting a sub in the boot.
BTW did i mention im a tight ass , so cheaper the better , but i dont want super crap :)
https://www.sau.com.au/forums/topic/109897-after-some-audio-advice-guys/
I would remove the 4x6 and put a set of JBL 6" (or similar speakers) in the front doors and a second set of 6" in the rear.
amp isn't really needed on something that small.
Just to offer up an alternative viewpoint; seeing as you're seated at the front and your ears face forwards I would leave the rear speakers factory for now. The only time we bother upgrading the rear speakers is if you either A; have people in the rear all the time or B; run surround sound. I'd love to sell you another set but you really do not need to upgrade them.
Why not inject all your funds into the front where you are? Maybe spend that money saved (on not buying rears) on some sound deadening?
As far as an amplifier goes, I would suggest something similar to Chris in that I would first try it with just the deck. You might find the decks internal amplifier is powerful enough to satify your listening levels. If it is not, then go for the amplifier option. :P
That sounds good to me. Where are you located? If you're in QLD you might want to go and see Chris (Audio Express) as he can set you up with all your speakers needs.
Just to further explain what I was talking about when I said you sit at the front and your ears face forwards. The Pinna (also called the auricle) is the visible part of the outer ear. It collects sound and directs it into the outer ear canal. Ass you can see (and feel) if faces forwards therefore placing speakers in the rear isn't really necessary.:P
This is the reason many demo and competition cars have their rear speakers turned down or simply don't have them at all. :)
Note; obviously this rule doesn't apply if you're using surround sound.;)
Thanks for the info mate , im from ballarat VIC. The JBL 6x4 in the front are new , they were the only ones i could fit into the factory door mounts. I didnt want to have to cut shit etc.
I was thinking maybe the JBL 6x9 in the rear would give me a little more overall bass ?? What do you think?
i think u should just disconnect the rear factroy speakers.
i know u dont want a sub but the best sound is if u have set of splits and a sub in the back.
6x9's is a waste of money in my eyes.
im running a set of alpine type R splits and a type R sub. with a 5 channel amp. And the slide touch headunit and sounds perfect. i know its a bit of money but u can go with a cheaper brand and will sound the same just not as clear.
but yea i think splits and sub the way to go.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
