Max Power about your XR6t I unfortunately work at Adrian Brien Ford, I have seen this happen alot. We had a staff member whos bought a turbo for her husband, it had some clutch problems they wouldn't do it under warranty - this caused a lot of problems around the place as the are so F***ing lazy when it comes to warranty work.(sorry you can probibly tell that I absolutely hate my job and work but this is the truth about warranty work in dealerships they make more money out of the customer than they do Ford)
I hope my warranty works as i had to come home from the cruise early as my clutch is playing up!
Edited by Whiplash
I hate to say it whiplash but the clutch want come under warranty because it is classed as wear and tear I think. I had to replace mine myself $4500 later. :D
wot u put in it a OS geinkin (spelling :S)
and did u do the work your self
i just got Kent brake and clutch to do mine and cost 800or 900 i cant remeber of the top of my head i think 900 for the GTS-4 with a HD xtreme clutch
BOUGHT MY CAR FROM rEDLINE AND I CANT SAY I HAVE HAD ANY PRBS WITH IT.... u DO PAY A LITTLE EXTRA FROM THEM BUT AT ELAST YOU KNOW YOUR GETTING A HALF DECENT CAR (MINE HAD THE AUCTION PAPERS AND STUFF COME ALONG WITH IT.... hAVNT HAD ANY PROBS AT ALL AND WHEN I GOT RAA CHECK THEY FIXED THE STUFF THAT WAS WRONG APART FROM MY REAR SPOILER LIGHT BECAUSE Icbf.
i went into redline a few weeks ago, looking around for my first skyline...however, i've been lurking round for a while checking out prices, and yeah they did seem a little expensive, 2-3k more than other places.
also, you'll be kinda hard pressed to find a GT-R there. the only one i saw was an R32. a lot of 32 and 33 GTS-T's, and most of these were pretty clean.
they're pretty good if you want a supra or 180sx as well, and one thing that i did notice that the brakes on a lot of the cars were very rusty, so that's something you probably should take into consideration when you look to buy...brakes aren't cheap.
new brake pads allways go rusty when i got new pads in my car i would get up and over night there was a rust like residue over my rotors
i dont think that is too much to worry about
A good option is interstate purchases, with RTA inspections and such .. They pick up pretty much everything and more in the way of faults. I saved myself quite a few thousand just by going interstate and driving it back (after taping up the front to prevent stone chips). I could've got it transported but how better to check a car for driving faults than driving it back from Sydney?
I went through http://www.japimports.com.au/ and found Brad Host to be a good, honest dealer. Couldnt be happier with my purchase, he even drove it to the airport for me to pick it up :happy:
They sell aftermarket warranties too for a reasonable price, not that I have had a need but I have called the firm querying. They cover almost everything, clutch, diffs, even exhaust :P
Maybe not relavent to the topic, but a possible other option :(
Interesting option, but do different states have different rules regarding compliance and what is and isn't legal?
For example, if I bought a car that was complied in VIC could it be possible that it is infact illegal in SA due to different laws? I am new to all these rules and regulations so please correct me if I am wrong..
Cheers for the link though!
^^^ yes that is spot on the money my opinion if u dont want to go over the pits @ regency is buy local
but it is a very good option too if u dont mind a visit to regency least it doesnt need full compliance i believe
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
