hey azz it got repaired back in late december......not a great job at all.
SHIT HOUSE DRIVER + SHIT TYRES + ME THINKIN I'M COOL = ME IN TYRE BARRIER
i'll be going back to eastern creek soon i hope
hows the build up going???
lol! yeah the build is comin along, very slowly!! though
  • Replies 41
Posted Images
Was out there for an hour to have a look see.
Was a laid back atmosphere.With some display cars (advan ''gracer'' and others) :D.The driving was good.I timed an evo there it was clocking 50sec laps and looked completly stock.John was there in the sled.Moanie and shif_tea were out there moanie was the only 1 driving though.waveS!!
As i was leaving i saw fats coming down in his gts-r.Well i cant confirm but im pretty sure it was him.waveS!!
Top day for a fang.
Unlucky Mona, I hope you can sort it out real soon. :)
Reedy in his R33 showed the way with his new oil cooler.
I lost my oil cap somewhere in the 1st session
and then my clutch decided to slip under boost,
but my mate Wizard in his bling auto Zed and the wrong side of 60,
slipped it around in the 51's. :sorcerer:
PS: Mona did you have a transponder in your car?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
