i posted this in general maintenance but didnt get a response, so i thought i'd try in here.
ive bought an n1 oil pump for my rebuild and ive been told by justjap that theyre a direct fit for rb25det. ive also heard from other sources that they arent a direct fit and need to be modified somehow, he said the actual pump needs to be modified, not the crank collar (which is what is needed for the rb30 I THINK).
whats the story with them? do they or dont they need to be modified?
https://www.sau.com.au/forums/topic/110104-n1-oil-pump-on-rb25det/
Why not street use? Arent there heaps of GTR's that run this pump on the street?
the n1 variants are for track use only and not street use.
i think i recall reading they are in fact worse for a street car.
they are designed for high constant revving and not plodding around a street, idling etc
another classic example of how this moderator is not helping the forum! =( Isn't it best not to comment if you don't know for sure what you're talking about?? talk about fundamentals.
I too can confirm it fits directly no modifications required. What people suggest in terms of modifying your rb25 setup, is the restriction of oil to to the head, as people have commented on this forum, that not enough oil is left in the sump at the pickup. To get around this, you can install a front mount oil cooler kit to add to the amount of oil capacity. It is recommended that a larger aftermarket sump be fitted if you intend to be constantly revving (ie drifting) or track use. But if not, then it will be fine.
what are you on about?
some of the stuff in your post isnt exactly accurate either :dry:
each to thier own
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
