  • Replies 47
Mate i did buy the Splitfires for the RB20/ series 1 RB25, but was able to swap them accordingly for a Series 2 RB25.
So if that is the case the coilpacks coming off the RB25 won't work :thanks:
But I can always ask what condition the coilpacks are like coming off the RB20......
Ando
Edited by R33Deviat
UPDATE - 28/03/06
After numerous discussions over the engine, it seems it is no ordinary RB25DET :D It seems it is a very legit low KM engine, so 24,000 seems to be accurate! It apparently is a VERY VERY LATE model RB25DET off a Stagea WGN33 with the sump modified for RWD..... :O
A few additions to the add-on list...
1. RB25DET
2. R33 GTST Gearbox
3. FMIC
4. Splitfire Coilpacks
5. 3" Exhaust Turbo back
6. Ceramic Clutch
7. 2 x Recaro's
8. Oil Cooler Kit
9. Profec B II Boost Controller
10. x3 Guages - Oil Temp / Pressure & Water temp
WATCH THIS SPACE FOR THE NEXT UPDATE! :(
Ando
UPDATE - 28/03/06
After numerous discussions over the engine, it seems it is no ordinary RB25DET :huh: It seems it is a very legit low KM engine, so 24,000 seems to be accurate! It apparently is a VERY VERY LATE model RB25DET off a Stagea WGN33 with the sump modified for RWD..... :)
Stageas came in RWD RB25 as well (just no one in australia seems to like or know about em), as did C34 Laurels, Glorias and Cedrics. Its pretty strange to modify an AWD RB25DET to a RWD when you can just get a RWD one cheaper and more easily.
Also the late late model RB engines are NEO engines, so make sure you get the right parts for it (eg: top feed injectors instead of sidefeed like regular RB25DETs).
Shan,
Mate it has me lost as to the exact nature of it.... I will see if I can get a piccy of it up for you guys to ponder over
Here you go!
:):huh::)
Ando
Edited by R33Deviat
Thanks heaps Nick!!!!
Yeah she is coming along nicely!! :) Just gotta feel sorry for Nath having to sort thru the wiring loom to match up to the RB25! ( See last 2 photos )
Doesn't a wiring loom hanging off the exhaust add about 2000+ rwkw?? :D
Ando
  • 1 month later...
*UPDATE 08/05/06*
Pit stopped @ the workshop on the weekend to pick up the RB20 / Gearbox and see my baby :worship:
Should be done in a few weeks time WOOT :spank:
It is 100% confirmed, engine is WGN34 Stagea RWD.
Just awaiting a couple of things such as, driveshaft modified for the 33 gearbox, power steering pump etc. Engine should be getting turned over in the next couple of days!
As for price (Basketcase) approx $4000 for engine (22K Km's), gearbox, coilpacks, full loom, AFM, ECU, delivered. Wasn't fussed paying a little extra considering the very low legit km's.
Ando
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
