A 1978 Gemini sedan, had it for a few yrs then did it up, candy red paint, rebuilt and no way near stock motor, man that thing did 14.5 1/4 mile times but it got stolen from my work carpark!!! ahh those were the days :P
  • Replies 61
vh commodore...
89 corolla
33gts
and now ....04 fiesta ....my god i drive the balls off this thing ...
its so fun :P ...although id give my right leg to have my skyline back ...actually ...no i wouldnt..then i couldnt drive it ...
id give my left testicle :P
99 Toyota corolla Karanda Green....manual sedan forgot the code...
00 Toyota corolla Silver manual sedan AE112R
98 R34 GTT (current)
Wouldnt mind getting another corolla as a run about.....with the amount of driving I do each day (approx 120km) it really leaves a massive hole in my wallet with the price of fuel these days.
But then again ive always wanted to turbo charge one of them new sportivos.....so yeah maybe not.....will get caught up in another project which I have no money for !
Edited by shonen
well my first car was a 1989 corolla Seca CSX
2) 1994 R33 Skyline GTS
3) 1994 Bluebird Attesa SR20DET AWD
4)And this afternoon i'll be picking up a R34 GT-T...
My r33 gts ;) love it to bits :yes:
As a matter of fact it recently came back from the repair shop, I made an arrangement with the repairer to get a new aftermarket front bar, 400R, instead of the factory one. :banana:
Below is a shot of it.. All I need now is some wheels.. and it lowered a teeny weeny bit.. :banana:
Edited by ignuz
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
