Matt - just wondering where your factory temp gauges sit's when it's up to temps and stable now with the DC16'er?
And when it turns on when your stopped still, how long does it run for??
Just wondering if I've got mine set at the right temp, I got a feeling I should drop it down just a tad.
Cheers
J
J,
I'll take a close look & get back to you on the exact position of the needle mate, rather than give a rough guestimate (a few needle widths below 1/2 way?) I do remember noticing it sat a bit higher than standard, but that was going from no FMIC & stock fan to FMIC & DC 16". It probably reads ~1 needle width higher than stock.
Same deal with the running time & so on, I'll monitor & let you know.
I've got the thermo s/w set below 1/2 way.
Thanks Matt, that'd be great.
ATM mine sit's a fraction below halfway, and when the fans turn on they usually stay on for about 1-2 minutes (on 30 degree days).
With the factory fan and intercooler I think it used to sit on about a third or maybe a bit more..
J
Originally posted by Steve
Any suggestions?
What about an undertray that sits between the air dam and the X-member. It should create a low-pressure area under the car by maintaining laminar flow at least until the X-member. It seemed to work OK on my Z.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
