had my car for a week now, it stalled twice on the way home (350km's), only at idle in traffic, did this today fixed it good.
nice idle now, but i turned it up a little to 700, rather than the factory 650.
yes the hoses are on there pretty hard, dont be scared, all the pipes they push onto are metal and pretty strong, get a large screw driver behind the edge to help push and give it a twist to break the seal a little, but dont jam a screw driver under the hose.
  • 4 weeks later...
managed to get it cleaned but had a hard time gettting the screw off from the aac.. there is a black rubber ring which i broke it when taking the screw out.. car doesnt have anymore stalling at idle but everytime when i clutched in my revs seems to stop at 1000rpm crusing then drop to 800 when car reaches complete stationary..
hmmm, mines back and with avengeance.
done about 3500km's since last post. ive cleaned the AFM, wrapped coil packs, gapped plugs, checked for air leaks, reset the computer but with no change.
seems like it only does it sometimes, at first it was only after hrs of driving and everything under the bonnet was warm, but yesterday happened just after leaving my folks place early in the morning.
i think maybe the AAC only works somtimes? maybe its a bit faulty or on the way out so it only does its job occasionally?
makes it real hard to sit in traffic sometimes, managed to control the stall but requires some fancy foot work...which id rather not do in traffic :laugh:
Has anyone done this to an R34 N/A (RB25 NEO)? I've had a look at mine and it seems quite different to the R33 in the pics.
I have no issues with my car at the moment.
I'm just curious - because I wouldn't mind cleaning it, for the sake of keeping it maintained and I imagine it would also help with idling economy too.
X 2 , I have a slighty fast and a tad eratic idling issue and I want to clean this out first as the throttle body will be the next likely culprit and that looks like a PITA to do.
My main concerns are the three water hoses with what looks like a bleed screw on the top that connect to the AAC housing as I'm not sure whether the entire plenum is water heated or just the aac housing or in fact WTF this hose Christmas tree is all about :merli: , the rest of it seems pretty straight forward .
Can anyone please help explain the hose thingos .??
I have noted that the carby cleaner is quite explicit about NOT allowing it to come in contact with any sensors, stepper motors and the like so it's obviously pretty toxic--it's a Nulon one, so I'll be dismounting the sensor and cleaning it with contact cleaner separately.
Edited by BASHO
I have a rb25det S1 in a 240 with q45 tb and freddy intake manifold. I messed with the tb screw a while back and just read that I wasnt suppose to mess with throttle body. Is it suppose to be closed?? Every time i mess with my idle I cant get it right. In order for me to crank the car I have to hit the gas pedal like a carb. When I disconnect the tb plug, adjust the idle and then plug the tb back up the car drop idle. can I adjust the idle with the car warmed up?? I cleaned out the aav like 6 months ago. How often does it need to be done??
Ok this may sounds strange ..but I decided to give this DIY a go myself on a 1998 R34 GT-T with about 65k on the odo as I have some slight idle hunting issues when clutching in at the lights etc
So I removed the 4 bolts (slightly different to R33) and loosened the hoses a bit ..but the hoses were really stuck on and so I though I'd just take a look inside the AAC housing to check its condition before I remove all the hoses etc and whaddya know ...
THE INSIDE LOOKS BRAND NEW. I am serious, there's not a TRACE of carbon buildup. All the walls look new and shiny and even the spring is shiny and looks brand new. No trace of dirt/carbon buildup ANYWHERE whatsoever.
Hm, what gives? Has anyone else cleaned the AAC valve/housing on their R34 GTT and found the same ?
hey i found that sometimes even if it looks clean give it a spray and some buildup will come out, worth a try .
how many km on yours ?
what happens if you remove the aac valve and adjust the idle with the tb.. Freind of mine with a ca18 removed his b/c his custom intake manifold was fitted for one? cause me personally, I hate the aac valve
65000 or thereabouts .. you don't get it, there is NO dirt in there. The pain of ripping those 4 hoses out to 'clean' something that is practically new inside is not worth it. The brass looks like brass and is shiny. The walls are still alloi colour and shiny/brand new (much cleaner and shinier than on the outside). No carbon deposits what-so-ever.
i found with mine was pretty clean but once you spray inside little holes and move the spring that's where i found most build up was.
how many rpm on idle?
did you check your afm ?
there was a post on someone fixing up afms by soldering connection, this might be the case also.
mine had a bit of issue with idle and i found by doing these steps it fixed now
I just couldnt justify screwing around with all the hoses (4 of them on the GTT) as they seemed very hard to get off after seeing how clean the inside was ..literally brand new or atleast looked that way. is your a GTT or v35?
my AFM wiring harness seems solid .. no loose wires. I'm gonna get a nissan consult cable (ecutalk.com) and check all the sensors using consult programs to make sure AFM voltage is ok etc.
RPM sits at 850-900 on idle ..no hunting, but when clutching in at lights, moving steering wheel when stationary it does hunt a bit (3-5 seconds)
OK, I cleaned the AAC valve on my 98 R34GT-t (79000ks) not (after taking it off) that it appeared to need cleaning, reasembled the thing, took it for a drive to get everything warmed up, unpluged the sensor, set the idle to 650rpm gave the engine a couple of mild revs waited for it to settle, pluged the sensor back in WAP back up to 800rpm WTF is it with this fricken thing.
I've reset the idle with the sensor pluged in but cant get better than 750rpm with the adjuster near closed.
I'm obviously missing something.
Any ideas anyone ?
Edited by BASHO
Any ideas anyone ?
Im having a similar problem but I messed with my q45 throttle body. And now I cant get my idle right or my tps. Thats what I get for messing with it. It was fine before. and this procedure isnt doing me any good......
ok im gona giv this ago on my r33 tomorow....now im abit worried about the screw thing....if i undo the idle screw to clean it, how do i no how much to tighten it to adjust the revs properly?
im worried that i might stuff up the revs and wont be able to correct it again
from wot i understood, u can adjust the revs of the car from that screw while its running??
any info would be a great help !!
  • 1 month later...
Like a few people said it may look clean but it still has build up.. if you really wanted to fix it you would be trying everything you read and not making assumptions on what it is.
  • 3 weeks later...
Just finished this... cleaned my R32 RB20DET, 95K on the clock real easy to get to 4 bolts at the back of the plenum lol my was full of carbon lol cleaned it all out got lucky too took the screw out cleaned it all up and put it back roughy were it was sitting b4 and now NO more stalling at lights and the idle sits dead on 750 now instead of jumping around 500 to 850 and only took about half an hour lol would also advise to cleaning the plenum were the aac valve bolts onto that was full of carbon too just used the cotten buds with carby cleaner on that but yeah great write up :cool:
Edited by nissans52
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
