Can anyone post up any pics of the mods to the oilways in the head & block. I'm just wondering which ones to drill out & which ones need opening/funneling out.
Cheers
Stu.
Very simple, all of the returns to the sump.
If it's not an oil return, then leave it alone.
Cheers
Gary
SydneyKid there is a hole in the block near to oil return... Is it a good idea to return the oils from the head there?
Depends on what block, generally speaking, no there isn't. That's why the suggested return is into the top LHS of the sump.
Cheers
Gary
  • 3 months later...
hey there,
just a question, ive read so much about the oil problems RB engines have, these cars arnt cheap to but, so much technology goes into development of these machines, and there seems to be about 6 problems with the oil side that sydneykid lists, why the hell have they not developed a better system of oil supply when testing their cars? or maybe nissan should have hired someone with a brain (sydneykid) to do the most critical part of a car engine????????
hey there,
Ask Nissan???
If the GTR's were used and driven as a stock road car with no power mods etc, they would be fine 90% of the time.
They did fix the oil pump drive from late R32GTR's onwards(thats about it).
As soon as you push beyond factory specs and set limitations, that's where all these mods come in handy I'm sure.
I was lucky enough to see the inside of the engine that gibson motorsport built for kerry packer's car back in 91 last week. while they had made some mods, they didn't have:
external oil return
restrictor in feed to head (in fact they had opened both feeds!)
wide drive on the oil pump
expanded internal oil return at the rear of the block.
I think it is fair to say the development that gary and the race team have done on these motors over many years, and they fact they have been willing to share the knowledge at no cost is very valuable to everyone on these forums
oh, and it spun a bearing on its first track day....
external oil return
Ouchhhh! That's expensive. How much was the engine back then....~150-200g?
Dunc, what changes have been made on the engine/car that caused the spun bearing? Was there any new oil pump, was the rpm limit raised, stickier tyres etc etc?
Cheap compared to a f--ked engine or engines especially if you plan on doing a lot of klm's on the track.
Dazmo, what kind of dollar is it for your dry sump and is there anyway of fitting one into a rb with Aircond and power steering intact :D?
You drill the smaller round holes to 9mm right?
I'm drilling mine out to 10mm, to match the head gasket.
Diameter of one of the oil drain holes, where it steps to the larger diameter is 9.65mm, and gasket was 10mm.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
