I am pretty sure that 25 neo's can only do 195-205rwkw max from stock turbo.
Thats 261.50-274.90rwhp.
how is an older less powerfull rb25 going to put out more power with fewer mods?
it isnt, stop talking shit.
or point me in the direction of threads of people posting dyno sheets to show otherwise.
well to prove that my one is truthful here is the dyno sheet!!! 302rwhp!!!
Edited by Wildcat
  • Replies 164
here's a standard turbo running 7psi , standard spec rebuilt motor with a HKS 264 deg exhaust cam set at '0' deg. It has a S-afc and factory ecu, large bosch fuel pump (from when the motor ran nitrous). Runs a turbo back exhaust and factory intercooler.
The rich mixtures are due to the fact that I was selling it to someone and I wanted it to be reliable from the get go. He was also not yet used to the power so the very mild tune was to keep him alive long enough to allow him to re-tune.
The change to the exhaust cam took away the 'bump' even without the ecu upgrade.
This car wherever it is could easily be tuned to run walk in the park high 12's even without a decent launch.
Another example of how good the factory turbo is can be found in 2rismo's car, even without my old nitrous kit he was able to run into the 12's. With the kit switched on he runs 11's.
Pulp i dont know how it pulled that much
1st run Mods 3, mandral bent exhaust from turbo back and hfc
cypher pod fillter
Psi in wangara first run 242rwhp 10 psi
they spun out there was another customer there and he said i was pulling more than his r33 and he had piggy back ecu and frontmount + my mods and it was manual
2nd xspeed after front mount and eboost 240rwhp at 8psi and then 250 and 10psi
i told them about psi effort and they said psis dyno would have been stuffed then my baby busted out the 250rwhp
the turbo looks stock and i have not touched the it but i was told it MUST have been hiflowed to pull that power
i have all ways kept it serviced by the same mechanic
james
Edited by Miller the hoon
That dyno printout that Wildcat posted is of my car..... And as far as we are aware its still got the stock ECU, with just the piggy backed AVC-R to control the boost and a SAFC-II to control air/fuel mixtures... the timing and air/fuel was played around with and at some times the curve did smooth out a bit but it cost HP up the top end.... The curve might not look as smooth as the other one you posted but I dont find it a problem at all when driving....
its one thing to be able to make the power its another not to have too much knock and blow shit up in the car.. my r34 gtt made 297rwhp but had to be put a lil down to 268hp cuz my engin was knockin way too much and i have a very hevy foot.plus i would hait not to have a reliable car.. but gettin 319 outa a stock r33 sounds very sus as i have got a 3.5inch exohst all the way, fule regulator, pfc, ebc, pot filter,fmic and a few more mods to be able to make that power but i still need engin internals to be able to take push it a lil more.. i cant picture how a gtst r33 can make more than an r34 with less mods!! and the r34s have Veriable Valve timeing too wich should add some edge.. i agree with noise. newer car means better engin although the ciramic turbo in the r34s limts us to max of 15psi our engins start knockin alot at about 13psi with 98octane fule that is how ever the car u guys were talkin about doesnt have a pfc do u probebly dont know howmuch knockin u gettin unless ur usein a dig tool for it..
s2 33 has vvt also, not sure if s1 do.
friends ex r33 made well over 350 rwhp on stock internals, and for more then a week. 320 is a walk in the park.
13psi causes me motor to knock does it? is that 13 psi with a stock turbo? a gt30r? t88? because they all flow the equal same amount of air at 13psi....
a stock 34 turbo is out of puff before a 33 one. dont forget that.
dude if your engines start knocking at only 13 psi something is very wrong hey and as long as they're tuned right, the stock rb's can make very decent hp on standard internals
if i had those mods and i had knocking at 13psi i'd fire my tuner asap
' date='24 Mar 2006, 10:49 AM' post='2044831']
No way in hell its making that sort of power with totally stock bits
cams, headwork ?
maybe more capacity ?
what sort of correction on the dyno?
is the dyno currently dyno dynamics accredited?
No Cams or headwork that we know of. Definitly standard capacity as NIB said the car looks like it has never been touched.
Has been running with the stated mods for more than 2years now at the same boost level and never had any engine troubles so reliable??? HELL YEAH... I guess we can all just say that this car is just a freak or posible hi flow turbo?? We wont know until we pull it apart I guess...
' date='26 Mar 2006, 07:41 PM' post='2048856']
2rismo uses nos to make his power :thumbsup: CHEATER! :D
What time has this 33 set with 320 (sAfrican American) rwhp
thats got to be mid 12 with good mph....
runs 12's without nitrous tho' on the stocker turbo.......
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
